Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 11-04-2012, 07:27 AM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
HVAC blower motor not working
First off I'd like to say hello to everyone again because I haven't been on here in awhile, so Hello everyone. But like the title says the blower motor stopped working (at any speed). If i take out the resistor and put it back in it will work again, but after driving it and then letting it sit for more than a half hour it won't work again. Any ideas?
Old 11-04-2012, 06:10 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
I thought you got rid of your e30! Although, I have no idea what's wrong :-P
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 11-04-2012, 06:38 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
are the connections on the bottom of the resistor corroded at all ?
havn't you replaced that resistor twice now ?
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 11-06-2012, 12:10 PM
Krumchev2's Avatar
Straight Bimmin
yeah i've replaced the resistor twice now but the one I have in now seems to be fine, but even if the resistor was bad wouldn't it still work on 4?
Old 11-09-2012, 03:40 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
Unless the actual fan rotary switch is not operational?
Or a possible fuse break?
Old 11-10-2012, 10:27 PM
Krumchev2's Avatar
Straight Bimmin
I'm pretty knowledgable about cars and the fuse was the first thing I checked. And I also jumped the switch and still nothing
Old 11-11-2012, 02:02 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
possibly worn out wiring, its not uncommon, its exposed to moisture from your windscreen and potentially heater core if its starting to get perished, combined with fresh air and heat = corrosion.
the switch runs via a relay, it could be this that is dead. on a RHD car you will need to drop the drivers kick panel and you will see the relay there, on a LHD it may be you need to drop the glovebox, or maybe they relocate it to your drivers side, not sure of course as we dont have LHD here.
Old 11-28-2012, 08:26 PM
Krumchev2's Avatar
Straight Bimmin
So I tried taking the blower motor out yesterday and cleaning it out thinking it might have been just dirt inside the motor. But when I put it back in, it worked on all 4 setting for the first time it ran, but once I turned it off to go into sears to replace a socket wrench I broke (only in there for like 10 minutes) it didn't turn back on again. I just don't get how it could work for alittle bit everytime I disconnect it but then stop working after I shut the car off
Old 11-28-2012, 08:35 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Brushes are worn out. Getting intermittent in their connections.
Sent from my MB860 using Bimmer App
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 11-28-2012, 08:38 PM
Krumchev2's Avatar
Straight Bimmin
So you're saying its the brushes inside the motor itself not always making contact?
Old 11-30-2012, 11:54 AM
Krumchev2's Avatar
Straight Bimmin
So do I need a whole new blower motor?
Old 11-30-2012, 12:04 PM
D'oh, You kids!
Correct. They are probably worn down to nubbins and the springs can no longer push them solidly against the commutator.
Not necessarily. You may be able to replace just the brushes, or have an electric motor shop do it for you. They could determine if it's viable to rebuild the motor for a lot less than the cost of a motor. If it's shot, you're only out a few bucks. If it's salvageable, the repair should be MUCH less than a new motor.
You can DIY some of them if you can find brushes that fit. I've replaced blower brushes in GMs before, using alternator brushes, but I have yet to do a BMW blower.
Quotes to live by:
BMW-CCA #441426
Old 12-01-2012, 11:02 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
From talking with J&N Auto Electric here in Cincinnati, these motors are not rebuildable. I went to my local U-Pull and Pay and found one for 6 bucks and put it in one and half years ago, it squeeks a little sometimes but works really well.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
