Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 11-04-2012, 01:27 PM
Gold323Ci Gold323Ci is offline
Mein Auto: 08 650i, 07 530i, 06 330i
Help w/ 650i hesitation and lack of smoothness
I recently purchased an 08 650i Convertible. It often times seems not to run very smoothly and hesitates a bit when running at slow speed. When driving on the freeway, it seems to run fine.
About 3 times in a month, it has had some obvious rough running and hesitation when first starting.
The car has 42,000 miles. Any ideas? I thought about using some injector cleaner to see if that would help. There's no check engine light or any other warnings.
Thanks.
Old 11-04-2012, 04:58 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2012 528i + 2007 650 Vert
Thanks.
Try the transmission reset procedure. Car in full on position but not started. Hold the gas pedal down for 45-60 seconds. That resets the trans. Have a look here for the thread. Frequently gets great results.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....12' F10/White
Old 11-04-2012, 05:06 PM
HerbP HerbP is offline
Thanks.
If the car is not driven enough, the battery voltage being low will cause this when cold. After the engine warms up this will usually go away.
Old 11-06-2012, 06:49 AM
Thanks for the posts. I tried the tranny reset last night but wasn't sure I noticed any big change.
My issue is a bit intermittent. It's not always there but is at times.
I'm not sure I understand the battery post. I'm not sure how that would affect my issue.
Old 11-06-2012, 07:14 AM
Low voltage will act the car to act strange. If the battery is weak, the ECM will do a load shed so the major components get power. After the engine gets warm, the battery gets charged some to compensate for the low voltage. My guess is the only time you see this is early morning starts?
