Engine bogging fixed - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 11-04-2012, 01:43 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
So today I decided to look at what was the reason my engine was bogging down and sounded like only 5 of the 6 pistons were working. I've ran into these issues in the past but both have been 2 different scenarios. One time it was a fuel injector that had failed. The other time I swapped the spark plugs and that did the trick. Today, a spark plug was broken, the top of the plug came out with the plug boot!
They had about 7k on them. They were Bosch, so I picked up some NGK plugs installed them and problem solved. Now time to wash the bimmer
Old 11-05-2012, 01:31 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
So I guess you got the broken plug out OK?
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 11-05-2012, 05:27 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
More of a question, does NGK make an iridium for the e36 yet...course I am asking primarily about my 1995 325i (produced 10/95) the extention cycle for BMW trying to not run into problems with OBDII Compliance?!?! Thanks if you know...and even if you don't.
I am currently running Bosch Plus 4 # 4417, but am hearing Bosch is not the best choice for BMWs??
Old 11-05-2012, 05:42 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Bosch plugs are fine if you get the standard version, but not the +4 plugs. These engines tend to respond badly to +4 plugs. And yes, NGK does make iridium plugs.
1998 BMW 328is
1966 Pontiac GTO
Old 11-05-2012, 06:30 PM
Thank you for the info...I'll se if I can find a spec for the iridiums...or go convetional NGKs
