Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 11-04-2012, 04:21 PM
zmao zmao is offline
Mein Auto: BMW X3
2013 X3, Only one exhaust pipe works?
Hi, I have a 2013 X3 28i (2 Litre Turbo). Recently, I've noticed that there is only vapor coming out of one of exhaust pipes (right pipe). Does the exhaust work this way or is something wrong? Thanks a lot!
Old 11-04-2012, 06:35 PM
Vortec4800 Vortec4800 is offline
Mein Auto: 13 X3 35i MSport, 09 135i
This is the way that it works. When you go above a certain RPM (~4k IIRC) the other pipe opens up as well. There is a way you can make both exhaust tips work all the time (search for golf tee mod) but it gets a little droney for my taste.
Note that if you try the mod, some places tell you to go under the car and unhook a vacuum line and plug it with a golf tee. Better approach for us is to unplug the solenoid in the hatch just behind the access panel on the left side. It's the only plug back there that looks like that.
Old 11-04-2012, 06:52 PM
Mein Auto: BMW X3
Thanks very much! Really appreciate your explanation!!!
Old 11-05-2012, 12:06 PM
SpaceManGray SpaceManGray is offline
Mein Auto: 2011 X3 35i
I want to add that this is done to increase back pressure at low RPMs. I believe this has an important effect on the turbo performance, so I wouldn't modify this behavior unless you really know why you want to make the change.
2011 X3 (F25) xDrive 35i 3.0L, nav, xm
Old 11-05-2012, 05:45 PM
Mein Auto: BMW X3
Thank you both!
