E46 (1999 - 2006)
Old 11-05-2012, 12:33 PM
Greekgod1 Greekgod1 is offline
Mein Auto: BMW 325I 2001
What is this? (newowner)
Well i was in reverse until i figured out it could go into a another gear, lol i know im stupid. But it can go into S, Then M1 , M2, M3, M4, M5? Im guessing thats manual, but whats the S for? thanks
Old 11-05-2012, 12:40 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Welcome...
http://www.bimmerfest.com/wiki/index.php/BMW_E46
Find the link to PDF version of your owner's manual and read it.
Jeff R.
Old 11-05-2012, 12:42 PM
It would be a lot more helpful if someone just told me.
Old 11-05-2012, 12:53 PM
SPDSKTR SPDSKTR is offline
I'm a DlCK! So what?
Mein Auto: E46 ZHP TS2+ Coupe
This took me literally 45 seconds to do.
Originally Posted by BMW E46 Owner's Manual for 325i
M/S Manual operation and Sport Program
Shifting from D into M/S activates the Sport Program. This is indicated by "SD" in the gear selection display. This position is recommended for a performance-oriented driving style. With the first brief ouch, the automatic transmission shifts from the Sport Program to the manual mode. When you move the selector lever forward in the "+" direction, the transmission shifts up. When the lever is moved back in the "–" direction, the transmission shifts down. M1 to M5 appear in the gear indicator.
Upshifts or downshifts will only be carried out by the ATC at appropriate engine speeds and road speeds. If the engine speed is too high, for instance, a downshift will not be executed. The gear selected will appear briefly in the instrument cluster followed by the current gear.
To accelerate quickly in the manual mode (to pass another vehicle, for instance), shift down manually or employ the kickdown mode.
Shifting from M/S to the selector lever positions P, R and N is possible only by going through D.
Old 11-05-2012, 12:55 PM
Territory Territory is offline
Mein Auto: 2013 x1 sDrive28i
S is for sport mode. It is still automatic. The car will shift less frequently (i.e., get closer to redline) and, when the kick pedal is pressed, will lower the gear to increase acceleration of possible.
That's the gist of it anyway. Use for fun!
Sent from my Galaxy Nexus using Bimmer App
Old 11-05-2012, 01:53 PM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
Give a man a fish.......... well you know the rest
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 11-05-2012, 04:33 PM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Basically, S mode gives you about 500 more rpm before shifting.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 11-05-2012, 05:41 PM
tcphoto's Avatar
tcphoto tcphoto is offline
Mein Auto: '01 325Cic TiAg
Translation, "I'm much too important to actually do it myself".
