E30 (1982 - 1993)
Old 11-05-2012, 11:44 PM
JasonHebb JasonHebb is offline
Mein Auto: 1989 325 IX
Massive coolant leak but where from?
Hello there! I have just bought an e30 (my first BMW!!) I checked all the fluids took it for a drive and it ran great and everything checked out. But the other day on my drive I took off the coolant filler cap to put some more in and loads of coolant started running out from underneath the engine. The leak has slowed now but I cannot find where it is coming from, all the hoses look and feel good as do the clamps and the leak is coming from somewhere between the engine and the fan. I managed to get my iphone in to take a video, can anyone think where this is coming from, do I need a new water pump and gasket? Any advice would be great as I would like this car to be back on the road before the snow starts ideally...
youtube
/watch?v=t-GFTqdWiSs&feature
Thanks!
Old 11-06-2012, 05:17 PM
downhiller's Avatar
livin large
bad link
Old 11-06-2012, 06:02 PM
It wouldn't let me post it as a proper link if you just copy the /watch... part after youtube.com then it should work I just tried it.
Old 11-06-2012, 07:33 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
link to video : http://tinyurl.com/ax7ub4f
Is it dripping out from the bottom of the water pump?
Old 11-06-2012, 07:36 PM
hornhospital's Avatar
D'oh, You Kids!
double post....
Quotes to live by:
Old 11-06-2012, 07:37 PM
D'oh, You Kids!
Here's the video. Your link didn't work, even copying everything after /........ (talking to OP)
That's coming from either the thermostat housing or the water pump. My guess is water pump. Replace the cam drive belt while you're in there.
Quotes to live by:
Old 11-06-2012, 07:41 PM
D'oh, You Kids!
No, that's the front crank pulley and timing pulse ring.
Quotes to live by:
Old 11-06-2012, 07:43 PM
yea , I realized that, I meant dripping down over it
Old 11-06-2012, 11:07 PM
BMWFatherFigure's Avatar
Old School
Quite possible. Feel under it with your hand. Also check with torch and mirror. Any leak that big cannot hide.
Current:
E38 Parts Car
Previous:
Old 11-07-2012, 12:07 AM
Cheers for the advice guys and thanks Tim96 and Hornhospital for getting my video up! I guess this will be an expensive trip to the mechanic as all I have is a load of screwdrives an adjustable wrench and a pair of dogs..
Old 11-07-2012, 12:12 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
You have more tools than most dealerships in Africa
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 11-07-2012, 06:08 AM
7pilot 7pilot is online now
Git
Mein Auto: 90 Ford Tempo
I'd strongly suspect the water pump.
It would be easy to spot if it was coming out under pressure from the thermostat flange.
m
Old 11-07-2012, 06:13 AM
EASiii EASiii is offline
Mein Auto: 328 CI
My expansion tank on my E46 spang a leak and it was gushing alot when the engine was on and hot, slowed when engine was cold and when pressure was low.
advice, antifreeze, bmw 325ix, coolant, leak, radiator
