Old 11-06-2012, 10:48 AM
Linseman Linseman is offline
Mein Auto: 740il
Transmission?
Car seems to lose power quickly when not accelerating. Even going down hill the car slows itself down. If I throw it in neutral, it will then pick up speed. Spark plugs and air filter have been changed regularly for what that's worth.
Could this possibly be a transmission problem?
Could the mass air flow sensor possibly need to be replaced?
Any input would be helpful.
Old 12-02-2012, 09:55 PM
Gc740il Gc740il is offline
Mein Auto: 1999 740il
I have the same problem
Old 12-14-2012, 05:31 PM
zachiepie zachiepie is offline
Mein Auto: 1997 328is, 2001 750is
Mine actually does that too. I used to drive an ambulance with a Ford powerstroke body, and that truck did the same thing. Apparently those have the same transmissions (labeled differently) as the e38s.
Old 12-19-2012, 11:22 PM
bmw2qnj2le bmw2qnj2le is offline
BMW740i
Mein Auto: 740i
Few days ago, my 2001 740i had the "TRANS. FAILSAFE PROG." display. My bimmer lost acceleration on the 1st gear. It accelerated slowly... I thought of low trans. fluid. In the Bimmerfest, some one explains due to the moisture/water condensation causing the electrical short that triggers the computer senses something was wrong with the trans. In the afternoon, my car drives normally without touching/fixing anything. Any inputs from experienced Bimmer would shed some truth!. Thanks in advance. BMW2QNJ2LE
Old 12-20-2012, 06:50 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Often, this message comes on, when the transmission module does not receive sufficient power/voltage. This could be due to damaged wiring, loose connection and even bad alternator/battery.
Any transmission failure/issue inspection should began with level, color and smell of the transmission fluid.
PS: NOT a transmission specialist.
JOY = BMW
HTML code is Off
