E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
idling problem
please help! |
Please make only one thread if you have related problems. It makes it easier for us to help you. Also... it helps if you actually have a question.
-CJ
Ok sorry about that and I'm wondering why it's idling weird and how to fix it
It kinda sounds like it is idling rough. Any check engine light? And are you sure the check engine bulb is working?
-CJ
I will check but I'm pretty sure it is , any suggestions to try ?
To see if the CEL is working? Turn the key to the third position (right before the starter) and the CEL should light up, along with the oil pressure light and others.
-CJ
nope not working
Ok, then you'll need to remove the cluster and replace the bulb.
Here is a good DIY for removing the cluster: http://forums.bimmerforums.com/forum...d.php?t=337504
-CJ
I don't see or hear anything wrong. Sounds just like a BMW 4-cylinder with an aftermarket exhaust.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
Ok thanks zegerman , and I will do that tomorrow as soon as I get a new bulb , what could be causing the weird idling then ? After market exhaust?
Ze German your like that mechanic genius friend everyone has haha !
What is weird about your idling? Looks normal to me. Seems like you just revved it, and then the idle settled down at the correct speed as it should.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild Last edited by ZeGerman; 11-06-2012 at 05:29 PM. |
This^. It idles exactly like my 318.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
i reved it up then it sits at 1000 for a little and slowly makes its way to 500 ish
thanks for that diy too i found another one to fix my steering wheel squeak
I think what you are experiencing is normal, and it looks as though your engine was not fully up to operating temperature either, which will cause the revs to hang a little bit.
Oh ok
| Bookmarks |
| Tags |
| 318, idle, rough |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
