E90/E91/E92/E93 (2006 - 2013)
| View Poll Results: Which is the best Battery Tender for my E9X BMW | |||
| Get a CTEK Smart Charger |
19 | 39.58% |
| Get a Deltran Battery Tender |
21 | 43.75% |
| I have neither but I just wanted to vote |
8 | 16.67% |
| Voters: 48. You may not vote on this poll | |||
#51
I have the same model. My third year with it, no issues. |
#52
My wife started reporting that she was having the low battery warning periodically. She's been working a lot for a couple of months now, usually 7 days a week getting the financials ready for the auditors and tax preparers, so the car is pretty much being drive 10 miles to and from her office with no time for weekend canyon carving or any longer trips. About a week ago we went out for take-out and while she was sitting in the car with the radio on the car shut down. Fortunately, it started right up when I returned with the food, but it's clear that her battery need recharging. I also decided on the CTEK 3300 and it arrived today. There are only three modes with one mode indicated as the "normal setting" and another mode indicated as being "recommended for many AGM batteries like Optima, Maxxima, and Odysses". So for the BMW OEM battery in an E92 should the mode be set to "Normal (14.4V)" or the AGM mode (14.7)?
- Tom ------- Mine: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12Hers: 2011 335is Coupe (E92) | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11 BMWCCA #444696 - Click to join and a chance to win a 1-Day M School at the BMW Performance Center!
#53
Where are you guys picking these up from? I'm thinking of getting one because I get the battery symbol if I leave my radio on for less than a minute after shutting the car off. I have a 5 mile commute and in most cases my car isn't warmed up by the time I reach work. But I do a lot of 20-30 mile drives on the weekends and in the evenings.
I've also noticed that my CA for lowering the convertible top doesn't work in the morning and I think it might be related to the battery being low on juice.
2009 335i 6MT M-Sport AW/CR Convertible & Border Collie |
#54
Amazon.com.
CTEK 7002 on Amazon, $96.98, Prime Can anyone with a CTEK 3300 tell me in which mode they set it for an E9x?
#56
You would have to confirm, but I think the higher rate is fine even if your battery wasn't AGM, if the weather was "cold". I personally use the lower/normal rate on my truck. As far as I know, my BMW is still using the original battery, the car is over 5 y.o., and everything seems to be working just fine. The 7002 is capable of an even higher voltage at 15.7, but I'm sure you already knew that. |
#57
I was also surprised that the terminals in the two cars differed so much. In my M Roadster the positive and negative terminals are large hex bolts and it appears that I may be able to unscrew them and mount the eyelet connector permanently, but in the 335is the positive terminal is a large c-shaped piece of copper and the negative terminal is a post that looks like it's a reverse torx bolt that's threaded internally. It looks like I could drill the positive copper terminal and bolt the eyelet connector to it. I'll have to investigate more tomorrow.
#58
Although you got the battery replaced and don't care about the old dead one anymore, I'd say the battery is bad. My tacoma battery doesnt hold a charge after a couple of days. I had 3 people all run diagnostics on it even thinking it was a short. Batteries dont last forever and sometimes are built to last a day. :lol:
#59
Also, has anyone used the solar chargers?
#60
Yes. They work well. But not at night, in the shade, or when it's raining.
#61
Bwaaahaaahaaahaaaaaaaaa! I scorn your puny battery tenders!
#62
Some more q's.
My battery light comes on if I leave the car in acc for a while. I have an apt next week with my dealer to look into this as well as some other non-related issues. If they refuse to replace the battery I plan to recondition it with the ctek 7002. With that - 1) Do I need to disconnect the battery from the car? Are the pulses for desulfation safe for the car's electronics? 2) If the battery becomes magically like new again, would the car properly adapt its charging algorithms (old vs reconditioned battery)?
#63
2. It won't be totally as-new; mine tested to 43Ah and is labelled a 90Ah battery. After reconditioning via CTEK the car still had issues in the first week. At that point I installed a new battery (no registration). It still had issues for at least a week but on testing at the end of the second week all was fine. From this I deduce the car eventually figured out it had a different battery When a DCAN cable arrived I registered my battery. What you decide to do is up to. Technically it should be a new battery and registration. Personally next time I will go the recondition route and run the car a few weeks to see if it improves.
![]() Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93) 28 vehicles in 26 years of driving so far. Guess I like cars
#64
Looks like you had the white - non-agm battery. What was the Ah after you tried to recondition it? What type of errors were you getting?
I spoke to my mechanic and he said it isn't good to leave these cars disconnected because they will throw some codes. He didn't seem convinced about my plan to recondition the battery. I still think its worth a shot if I can make this battery last a year or two longer. Wondering if I should hook up a trickle charger to the car when the battery is disconnected. Thoughts?
#65
D690 1 Error Stored 20 A559 1 Error Stored 20 Quote:
I left mine disconnected for quite a while. The car is fine. Certainly don't run the recondition mode with disconnecting - likely it would be fine but better safe than sorry. If it all bothers you buy a new battery and DCAN cable. Registration is super simple using Tool32 (IIRC).
#66
I've had a battery tender on my bike for the last 6+ years and my battery just finally died. That's a long time to keep a cycle battery alive. I keep it plugged in 24/7 when not riding and never had an issue.
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
#67
Keeping the battery running a bit longer has to be a good thing for everyone but people who sell them. Years ago they were user serviceable and we topped up cells with distilled water + the DIY types could use sodium sulphate to desulphate the plates. Lead lasts forever, sulphation and loss of liquid are the problems (AFAIK - not an expert, just know how to use Google). Aside: Today the spot price of lead is a little over one dollar per pound, likely ~40lbs of our 50lb lead acid batteries is lead. Plastic and distilled water cost next to nothing... so that $480 installed battery is likely under $45 in materials. Only a 10x mark up by the time we get it Update: The lawn tractor battery died again four weeks after reconditioning. I am beginning to doubt clams about reconditioning.
#68
Thanks for the info. I'm still under the 4/50k so I'll see what BMW does next week. My mechanic is honest, but not cheap. He takes more time to explain stuff to me than my SA at the dealer.
If not, I think I'll try to recondition it. I have a dcan cable so all is well.
2009 335i 6MT M-Sport AW/CR Convertible & Border Collie Last edited by unrealii; 03-01-2013 at 08:49 AM. |
#69
Me too. Went is several times between 10K and 11K miles with low battery light/ rough running issues. Dealer said the battery was fine. Problems persisted until I change the battery out.
#70
I've been reading a lot of posts about this and came across this. I dont think it has been mentioned before. If anyone with TIS access wants to reconfirm, that would be great:
#71
Battery tender works fine with my E60 through the underhood connections. However, a buddy came over for some coding on his 2006 330i E90. We had the key in position 2 and had the tender connected under the hood. After about an hour we were finished and he needed a jump.
![]() He just wanted a jump so he could go home, meanwhile I'm stumped to the point that I could barely help him. I'm still trying to figure out what was going on. So I vote CTEK.
Check your mirrors as often as it takes for you to know where everyone is around you! |
#72
I received my ctek 7002 last week. Hooked it up Friday and it topped off the battery in a few hours. I clamped the ctek to the under hood posts. Saturday, I disconnected the neg terminal (I left the battery in the car and kept it well ventilated) and connected the ctek directly and ran the recondition. The recondition part took a about an hour (it does a full standard charge first before reconditioning). I let it sit for an hour or so without the charger then reconnected the terminal.
While the battery was disconnected, I mounted the permanent plug on the terminals under the hood. The proximity to the coolant expansion tank and all the heat generated has led me to consider putting a wire loom over the wires. I have a bunch of loom at my folk's house, so I'll be doing that within the next few weeks. Back to the ctek. Sleep voltage was 12.37-12.41v prior to reconditioning/charging. One day after reconditioning it is 12.53v. This has resolved two issues - 1) bluetooth remains on if on an active phone call when car is turned off, 2) Comfort access for convertible top works in the morning Few other things. When reconnecting the battery, I had to reset my clock. There was an idrive warning for that. I checked for codes using bmwlogger & usb dkan and it found none. I swung by my mechanic and his autologic tool detected a battery disconnected code (I dont know the number) and cleared it. Any thoughts on if this is an acceptable battery voltage? I'd like stretch the life of this battery out as much as possible.
#73
Give it two weeks with no CTEK charging. Leave the car with engine off + radio on in your garage and see if the low battery light appears. IMO this is as good a test as any. Please report back so we have another data point.
#74
Yeah, I'll keep an eye on it.
I took it to the dealer. Dealer said battery was ok. They ran a mid tronics test while doing the battery cable recall and that passed as well. Bluetooth decided not to stay on yesterday when I tested it after shutting the car off. I'll take some more volt readings in the morning and see. I might just bite the bullet and replace the battery if its still bad in a few weeks. I have different battles with the dealer to fight which are worth more time than this.
2009 335i 6MT M-Sport AW/CR Convertible & Border Collie Last edited by unrealii; 03-13-2013 at 08:40 AM. |
#75
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
