Old 06-28-2014, 02:17 PM
docphi12 docphi12 is offline
Mein Auto: 745Li
745Li DMTL Pump
I've got a 2005 745Li. Anyone know where this pump is located and how to get to it? Thanks!
Old 06-28-2014, 05:59 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
bimmerfest Supporting Member
Mein Auto: 05' 760li,94' H1,08'Smart
http://workshop-manuals.com/bmw/7_se...all_u/page_67/
Try this
Old 06-28-2014, 06:12 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
Behind right rear wheel arch trim
http://www.bimmerfest.com/forums/sho...578&highlight=
Old 06-28-2014, 08:01 PM
Mein Auto: 745Li
Thanks for the info guys. That's where I thought it might be. How hard is it to remove the wheel well liner? Thanks again!
Old 07-10-2014, 02:18 PM
Mein Auto: 745Li
Ok. Changed the pump. The pump was easy. Removing and replacing the wheel liner was a bear! Those pop rivets are worthless. Anyone know what the white and blue cylinders are that are clipped to the inside of the liner? Some kind of sensors?
Old 07-11-2014, 08:13 PM
Mein Auto: 745Li
So the pump replacement didn't work. I'm still getting the same error codes. The dealer scoped the car and said it was the pump and that's why I replaced it myself to save a few bucks. Anyone have any suggestions?
Old 07-11-2014, 08:50 PM
Did you reset the code and complete a drive cycle?
Old 07-11-2014, 09:08 PM
Mein Auto: 745Li
Yup. Reset the code and I've been driving it since yesterday with no issues. Today the code popped up again.
Old 07-17-2014, 06:27 PM
Mein Auto: 745Li
So my type A personality was driving me nuts and I had to figure this out. I had already changed the DMTL pump and drove a few drive cycles without any luck in resetting the monitors. So I dumped Seafoam in the gas tank and drove around for a couple of days without any luck. I pulled out my old laptop and booted up INPA to have a look around today. The mass air flow output was wacky and the EVAP and secondary air monitors weren't resetting. I ran a few rev tests and DMTL leak tests. The mass flow output improved so I reset all the codes and turned off the car. When I turned it back on it was intermittently revving and idling and finally settled down. Imagine my surprise when I found all monitors were functioning normally. Hopefully it'll stay that way. We'll see what happens over the next few days.
Old 12-21-2016, 12:53 PM
Tony F. Tony F. is offline
Mein Auto: 2004 745li
Issue
Sorry for the addition to an old post. I changed my DMTL pump (yes @docphi: the shield IS a bear to remove). Anyway, after removing and replacing pump. I am now getting DSC/ABS/Parking Brake Malfunction lights. Anyone know what i did wrong? Need help as soon as someone can get back to me. Need to know what to do before car has to be driven tomorrow!
Old 12-27-2016, 10:05 AM
Any help???
I am still trying to track down source of problem. Anyone???
