E90/E91/E92/E93 (2006 - 2013)
Old 11-07-2012, 10:14 AM
tshold tshold is offline
Mein Auto: 2009 328i
Heated Steering Wheel Problem
Hey everyone,
I finally bought myself a 2009 328i after saving for years. It's pretty much the car of my dreams but I have just one small issue that I was hoping to get some insight on.
From time to time, when I turn on my Heated Steering Wheel it will just turn off all on it's own before it even heats up. Other times it works perfectly. Has anyone else had this issue?
-Taylor
Old 11-07-2012, 11:34 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
You can search far and you can search wide....in fact, you can search this subforum, for "Heated Steering Wheel"....many hits....
Old 11-07-2012, 11:42 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi Sedan
I have not experienced this particular problem but have heard of it (which may be why I never run into it...keep reading ). Does this happen most often (or only) when you turn on the steering wheel heater immediately after starting the car? In that situation, the total electrical load can be very high (wheel heat, seat heater(s), HVAC blowing high to warm the interior, maybe headlights on, etc., etc.). As a result the steering wheel heat cuts out--whether this is designed into the system or just a quirk, I don't recall.
The official recommended "fix" per BMW is to wait a few seconds (10-15) after driving off before activating the steering wheel heat. That's enough time for the electrical load to stabilize/diminish, avoiding the problem. I have almost always done this and have yet to experience the wheel heater cutting out.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 11-07-2012, 11:43 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Mein Auto: 2009 335i xDrive coupe
There have been some reports of this in the past. The no-cost solution that seems to work most often is to wait for 10 - 20 seconds after starting the car before activating the heated steering wheel or the heated seats.
FWIW,
George
Edit: Ah, Zeichen and I post at functionally the same time, and his sneaks in first!
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 11-07-2012, 07:13 PM
Thanks guys. That completely makes sense. It always happens when I try turning it on right as I start the car. I'll give your advice a try tomorrow.
Old 11-07-2012, 07:58 PM
Braumin Braumin is offline
Mein Auto: 2009 335i xDrive Sedan
There is a service bulletin for the problem. It is SIB 32-01-09
I believe they change the heated steering wheel switch. I also need to get this done on my car it has the same thing happening. It will be under warranty if your 09 still has some left.
Here is a link:
http://www.edmunds.com/car-maintenan...12345&type=tsb
Vehicle: 2009 BMW 3 Series
Nature of Defect:
STEERING:WHEEL AND HANDLE BAR
Bulletin Number:
SIB-32-01-09
Bulletin Date:
Nov 2010
Summary:
BMW: IMMEDIATELY AFTER A COLD START IF ELECTRONIC COMPONENTS ARE TURNED ON SUCH AS HEATED SEATS IT MAY SWITCH OFF AFTER 5-10 SECONDS BECAUSE OF A VOLTAGE LEVEL DIP. ( NHTSA ITEM NUMBER - 10037537 )
Old 11-07-2012, 08:33 PM
sptt144 sptt144 is offline
I'm glad I don't have the NEED for a heated steering wheel. If it was that cold, I'd be wearing some gloves!
Old 11-07-2012, 08:34 PM
Ah gloves would just ruin the experience! I think the heated steering wheel is just one of the best things EVER! Well, maybe ever since heated seats came along
Old 11-08-2012, 08:09 AM
Spagolli94 Spagolli94 is offline
Mein Auto: 2006 330i
If I was buying a new car, I probably never would've thought to check this box. I mean, who really needs a heated steering wheel. But, my CPO I recently purchased has the heated steering wheel and now I'm hooked!!! It's literally one of my favorite features of the car and I from now on, it will be a must have option for me.
Old 11-11-2012, 07:12 PM
Well, it finally dipped into the 40's here in So Cal (at night). I got into my car the other night after work and was actually cold to me (with my light windbreaker on). I started the car and grabbed the cold steering wheel and thought, "it would feel good to have a heated steering wheel..." and this is not even the cold weather you all are living with! But I'm not sure we get too many models with that option out here unless ordered.
Old 11-12-2012, 12:33 AM
One of life's little pleasures, my motorcycle grips are heated too.
Don't be without!
Old 01-13-2013, 03:52 PM
WendyS WendyS is offline
Mein Auto: E92 2009 335xi
Sent about 1/2 hour today chipping my car out of a shell of ice (gotta love Wisconsin winters). Finally got in, started it; turned heated seat on high and steering wheel on... and then the steering wheel heat kept turning off ! (tried it about 5 times while driving). When I got home, I turned the car off and started it again, and the heated steering wheel button light stayed on and it worked fine. When I bought the car I rolled my eyes at the heated steering wheel, but then realized its awesomeness.
Old 01-13-2013, 05:20 PM
bap bap is offline
Mein Auto: E90 TIAG 335i
I have had good luck replacing fuse 75 at the start of winter. Seems to last a season then starts failing. Fuse checks out fine, but after replacing it I haven't had a recurrence for the rest of the winter.
Old 01-13-2013, 06:22 PM
Zooks527's Avatar
Two of my favorite features of my E92 are the REST button and the heated wheel. Sadly, one is non-existent on new 3-series, and the other can't co-exist with sport seats.
Another reason to keep maintaining my current one.
