Old 11-13-2012, 02:06 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
I could believe it was the gasket. one of thing that had crossed my mind.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 11-15-2012, 11:35 PM
akillies akillies is offline
99 540i Make Over
Mein Auto: 99 540i
O
Old 11-15-2012, 11:45 PM
99 540i Make Over
Mein Auto: 99 540i
Replacing the exhaust manifold gasket really worked well.. Now there is a barely noticeable shake and no fuel smell. The fumes smell was really bad and I did not know where it was coming from. I noticed the aux fan was making this really loud strenuous noise when it turned on, when they scanned it a code came up for the aux fan but I forget to write down the code. I will try to get it tomorrow. they think the mechanic who replaced my radiator messed up the fan some how. I am going to try sort it out tomorrow, any idea's?? This mechanic who changed my radiator is really pissing me off he put 5w40 instead of 10w40 like I told him and now the engine is running a little rougher, he told me there really is no difference but now I know the lubrication from 10w can help a lot. going to drain out the 5w and put 10w and the rislone treatment in.
Old 12-14-2012, 03:00 PM
99 540i Make Over
Mein Auto: 99 540i
Wow!! I found the obvious reason for the shaking and rough idle. The exhaust manifold gasket helped a log but the rest of the problem was due to a bad drives side motor mount. I can't believe none if the mechanics that looked at the car did not see the black goop coming out. The truth is both parts needed to be replaced.im just glad I'm not stuck with a partial shake because my mechanic said it was normal for an older car.. Thanks for all the help and insite.
Old 12-14-2012, 06:11 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
Black goop coming out? Of what?
BMWCCA#401441
Old 12-14-2012, 06:33 PM
Redrokit8 Redrokit8 is offline
Mein Auto: 02 325i / 02 Trans AM WS6
Originally Posted by caballero View Post
Unfortunately this seals are of very poor quality, BMW knows about this problem and they simply don't care. Google Bisan systems because that's the company that I use when I replace mine, I did mine about two years ago and I believe they cost me about 60.00 dollars good luck
Great tip. Also you may have oil that seeped down to your spark plugs when the valve cover gasket was replaced. I did.
Old 12-15-2012, 03:44 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
If you need a DIY:
- Motor mounts (aka engine mounts) and transmission mounts (aka holders) DIYs for the BMW E39 I6 (0) (1) (2) (3) (4) & for the V8 (1) (2) (3).
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 12-15-2012, 06:44 PM
99 540i Make Over
Mein Auto: 99 540i
I said black goop b/c that's what it looked like but the motor mount is either packed with grease or a thick oil. When it starts seepping out around the edges and/or when its visable you know it is bad and needs to be replaced.
