E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
no cluster after battery install
okay i have been messing with this for about a week now. 2004 530i had a dead battery we jumped it and all the gauges ,power doors and locks worked until the car started. replaced battery now have no power windows,doors,cluster,ac .. but radio turns on and won't turn off even with key out.
Was the battery replaced by BMW? Was it registered to the car after installation? If not, there are several threads about problems of this kind after do-it-yourself battery installation that may be of help.
no it was not installed by bmw, i installed it. the cluster worked on the dead battery if had jumper cables hooked up. now with the new battery it only starts. i had searched for a cuouple hours on the other "threads" and found nothing towards a resolution
What kind of battery did you replaced it with? Same cold cranking amp or bigger?
If you put anything smaller the computer will turn off electronics. |
Take it to get it registered.
Sent from Gus' pad |
Was the old battery tested and found to be bad. Sounds more like a bad IBS then battery. I would have the car scopes for faults.
z0lt3c Current: 2013 Ford Edge SEL AWD 2012 Jeep Grand Cherokee Laredo 4x4 Retired: 95 e36 M3/5spd, 96 328is/5spd, 97 540iA, 98 528iA, 01 X5 4.4iA, 03 325xiA, 04 530iA, 02 330Cic/5spd, 08 535xit |
^ I concur with the above post.
For this kind of problem, rather than guessing and replacing parts, I'd pay the diagnostic fee and let a competent mechanic/dealer find the root cause of the problem. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
