X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
X3 slid into curb in snow... Should I be worried?
Hi all. New to the forums here.
I was driving my x3 in the snow tonight and I was turning a corner at about 15 mph. The car slid and hit the curb. I drove it home for about 40 min and didn't hear or feel anything, nor did it look odd, other than the curb rash. Should I be worried? Is it likely that a problem will later problem develop with the wheels from the impact? Thank you!! |
Unless you bent a wheel, which should result in substantial vibration, it is unlikely you did anything to the suspension. The components are pretty beefy and there are rubber bushings at the suspension mounting points except of course the tie rod ends. So if your X3 steers straight without vibration, drive on.
Shouldn't be a problem based on speed. However, due to the cars weight, it might be worth having a wheel alignment check, if something went out of place it will show up and you can have it corrected.
Could be huge problem, you should just give the car to me.
Patrick ///98 328i hellrot///BMWCCA#465139 |
I would check my tire pressure before driving. If all are above 32 psi you should be fine. The only thing I would suggest is an alignment.
You need to get the alignment checked. There may be no apparent pulling but there are other factors like toe, camber, etc...angles that could adversely affect tire wear and handling.
was the wheel straight or turned at the time?
"This is sarcasm right?" |
Wow... some people are incredibly rude on here...
For those who were helpful and answered nicely. Thank you for the advice. The wheel was straight when I hit it. I guess I will go get a wheel alignment check done. Thanks again! |
How much does an alignment check typically cost?
An alignment can cost anywhere from $30 to $200. Call around to local auto places and find out for yourself. Us trying to tell you what something should cost in your area would be like trying to guess how many craters are on the moon. And you calling people rude is rude in and of itself. People hit curbs everyday - I am amazed that anyone has given this thread serious consideration.
I pay 180 at the BMW dealer to have my alignment done. It's probably worth having them check the suspension components while they're at it. Good luck. Accidents can happen to anyone.
but dont go in saying that you hit a curb, just say that you have not done it in a while, if you say you hit curb its gona be a jackpot for them
Didn't the xDrive kick in? where was the DCS ? sliding at 15 miles?
At 15 mph there was probably much more of a RWD bias than the more normal 40/60. But tire condition, road camber and other factors might have been a consideration in this instance. |
Sounds reasonable. I was impressed by the youtube videos showing BMW has steady control when making turns on snow field. This is one of the biggest factors that make me inclined to buying a BMW xDrive.
winters are 17" continental winter contact summers are 19" staggered continental DWS even if you hit black ice one a year that's the difference between going of the road and a big scare. definitely worth 1.2k and in the long run you're not paying my extra but are MUCH safer
do you put on your winter tires yourself or have a shop do it? Changing tire for a SUV with xDrive should not be easy, right? |
#25
| Bookmarks |
| Tags |
| accident, curb rash, e83, rims, x3 |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
