E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Brakes are kinda weak?
So my brakes are kinda weak, and while they do not squeak on the outside, the pedal does when i push it down, and it seems weak to push, so im wondering if it is the pads, the rotors, the pedal, or what...?
PS, I clearly know nothing about cars. PPS, My handbrake is so weak, that on a hill, fully engaged, on neutral, it still rolls. Thoughts on how to go about fixing this or what to do? |
Brake pads could be about done. Also, could be your brake hoses, after a while they expand when under pressure giving you a soft pedal. I had the same problem and decided to get new calipers, rotors, ceramic pads, and new hoses, now I have a nice firm pedal.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
You need to inspect your brakes , see if your pads are getting thin , how the rotors and calipers look. The slides could be sticking causing the increased effort at the pedal. It might be time for a brake job or a good service. I think that you really need to go in and clean and lubricate your slides just to keep everything operating correctly.
so the pedal has a soft feel? you have air in the lines which could mean, you have a leak. and i would point more towards a master cylinder. but definitely need to get them checked out. if you dont know cars very well, i would find a good shop.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
+1 on weak flexibles. Also full clean and lub on caliper pistons, slides, pins and mounts. Handbrake adjustment is through any of the rear wheel bolt holes, although I would suggest removing one side first. This will let you see the parts and how they interact, if the shoes are too worn and genrally make a decision on how much of a service is required. If it looks good when you check the first side (I doubt it) the you need only adjust the second side as you have a picture in your minds eye of what is going on.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
