Old 11-08-2012, 08:48 AM
xdjscri xdjscri is offline
Mein Auto: 2001 525i
Hurricane Sandy
my 2001 525i took in some water, enough to get my passenger underseat fuse holder wet/covered. Car cranks but won't fire and have some electrical issues. Got to the fuse holder, has some corrosion. Should i spend time/money cleaning/replacing the underseat fuse holder and fuses or is everything fried. No flood or comprehesive insurance. Thanks, Dennis
Old 11-08-2012, 09:28 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You could try that, but be aware. The car may never be right again, and may plague you with electrical problems.
Can you determine where else the water got, or how high it was in the car?
Old 11-08-2012, 09:49 AM
Jason5driver's Avatar
Let the car dry-out completely first...
Old 11-08-2012, 02:50 PM
Thank You. I got to clean all around the fuse box today. The two 3 wire terminals were badly corroded and disconnected from the box altogether as were the studs on the box. I disconnected all the wires from the box, the wires and the box are numbered so it makes it easy to reassemble them. I removed the box for closer inspection. The gunk/water only came up to the bottom third of the box where the two 3 wire terminals enter the box. I tested all the fuses and they were good. I cleaned the box, stripped the corroded wires back, rigged them to the box terminals and the car fired up with no check lights(praise the lord). I called Bavaria Used BMW parts and ordered a new(used) fuse box complete with wire pig tales. I told them my story and they shipped for free(nice of them). I can't wait to get it all back together and put all this hurricane crap behind me. Hope I don't have any further issues. Thanks again for the advice. Dennis
