E60 (2004 - 2010)
Old 11-08-2012, 09:34 AM
repoman75 repoman75 is offline
Mein Auto: 2008 535 xi
Check Engine Light
So for over a month now, the check engine light (the yellow light on the dashboard shaped like an engine) has come on.... it stays on for like 2 days, then goes off for 2 days, then back on for 2 days, then back off, etc. No errors in the iDrive, no performance issues whatsoever.
I will have the dealer look at it when I bring it in for inspection next month, but what do you guys think? Faulty sensor somewhere?
It first appeared after I had the turbos replaced... but again, no performance issues whatsoever.
Old 11-08-2012, 04:25 PM
GSG1 GSG1 is offline
Mein Auto: 07 525i, 05 S500 4Matic
Happend to me a few weeks ago. Did a scan and it was the MAF sensor. If it is, take the MAF out and try cleaning it with a MAF spray cleaner. One of the easiest DIY you can do. Sometimes that is enough. Clear the light and see how it goes. If it comes back with the MAF code again then you have to replace it.
Old 11-08-2012, 05:24 PM
Thanks! Can you detail where the MAF sensor is and how to remove it?
Old 11-08-2012, 06:01 PM
It's on the intake manifold near the air box. You have to remove 2 torx screws.
Here is a good post on it.
http://forums.5series.net/diy-do-you...diy-n52-98032/
Old 11-08-2012, 08:25 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i
The n54 engine does not have a maf sensor.
Repo man, if your car is under warranty take it to the dealer for them to pull error codes or if you have a code reader pull the codes yourself. It could be numerous different things so the error codes will help narrow down the issue.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs.
Old 11-09-2012, 06:14 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Mass Air Flow (MAF) sensor measures the amount of air going in to intake. All cars need some type of mechanism to measure the amount of air going in to intake. Almost all modern cars have MAF - on some cars, it's located in an obvious place right after the air filter on the intake tube and on other cars it may be buried along the intake.
Old 11-09-2012, 06:43 AM
Gustavoerod's Avatar
Gustavoerod Gustavoerod is offline
Mein Auto: 2006 530i
From experience if it is the MAF sensor it will give you performance issues, specially having turbos,
No disrespect, but if you do not know where to start looking for this sensor, take it to the dealer. Nothing better than knowing where to start looking based on a code.
Old 11-09-2012, 07:04 AM
booyaazaa's Avatar
Yes if you have a NA engine then you will have a maf sensor. But since the OP has a 08 535xi he has the n54 twin turbo engine that has a tmap sensor that measures temperature and manifold air pressure.
2009 AW 535i
Old 11-09-2012, 10:04 AM
Dealer it is I guess. And yes, NO performance issues whatsoever. And it goes off and comes back on almost regularly, every 48 hours.
