Old 11-14-2012, 06:24 AM
babyZ babyZ is offline
Enthusiast
Mein Auto: 1997 BMW Z3
Z3 Phantom Battery Drain
My car has decided it is no longer going to hold a charge over night.
Things I have checked:
Battery - it has been tested, but I suspect water in the casing + freezing temperatures
CEL's - All have been delt with - P0505 and P0455
Sound system - The entire system is ran through a bank and isolator switch
Any ideas past that that could be the culprit?
Old 11-14-2012, 06:45 AM
KBH22102 KBH22102 is offline
Mein Auto: 1997 Z3 2.8, 2002 M Coupe
Check if the wiring loom near your driver's side trunk hinge has frayed wires causing a short, or if you just haven't shut your trunk completely causing the trunk light to stay on continuously.
Old 11-14-2012, 07:30 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Start with http://www.bimmerfest.com/forums/sho...=battery+drain
Searching on "battery drain" will turn up a ton of info.
