Old 11-08-2012, 07:34 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Possible torque converter problem?
Strangest thing this morning, i go out to the car, drive out, I get to the first light and then the idle starts stumbling (fall, stablize, fall, etc). To add, while driving the revs would drop and regain like when i had my transmission problem, except this transmission was just rebuilt not to long ago! (2003 540i)
I swapped MAFs just to be sure, and it didn't do anything, still drove poorly.
I scanned the DME, clean. Didn't scan ABS since no lights came on. Scanned the Trans. got code "30 Mechanical converter lockup clutch monitoring"
Is this just a sensor or am I looking at a bad torque converter?
Droopy idle (This didn't come back later in the day) for some reason...
This is how it drives now
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 11-08-2012, 07:45 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Cryptic - is the clutch disengaging?
Old 11-08-2012, 08:34 PM
GabesJH82 GabesJH82 is offline
Mein Auto: 2002 BMW 530i
Im sorry to say but hopfully its not the torque converter cuz i got the same code and ended up replacing the torque converter and the code never came back.
Old 11-15-2012, 01:42 PM
Dking078's Avatar
Member Supremo
Mech. called up and said it's a bad solenoid. I'll check it out when I pick it up tomorrow.
Old 11-15-2012, 02:20 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
Whats the damage on the wallet?
Old 11-15-2012, 05:04 PM
Dking078's Avatar
Member Supremo
Not sure since im still under the rebuild warranty (1yr-12k)
The shop will report back to me in the morning and let me know if the solenoid fixed the problem. ATM their wrapping it up and will test drive it late today/ early tomorrow.
Old 11-17-2012, 10:25 AM
Dking078's Avatar
Member Supremo
Got a call back, it's definately is a solenoid.
The problem is that 2 are bad;
1 solenoid lets the car shift fine in/out of 1st but like poo in the rest. The other solenoid wont let it go into 1st (2nd is the lowest it goes/starts) but works fine in/out of the rest.
Old 11-21-2012, 11:01 AM
Dking078's Avatar
Member Supremo
Well bad news... the Solenoids didn't change anything for some reason.. The car still drops rpms in every gear... Any help is usefull.
The only possible cause I can think of at this point is the TQ converter.
Old 11-21-2012, 03:02 PM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
Idle RPM dropping and RPM surging while driving is not likely the convertor.
Clear the codes and see what codes set again. Is there more than one code?
Do you have or have access to a scanner that can look at the sensors while the engine is running?
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 11-21-2012, 04:24 PM
Dking078's Avatar
Member Supremo
Is there more than one code? No
Do you have or have access to a scanner that can look at the sensors while the engine is running?Yes, but the car is at my mechanics, but they say they have readers too, but i did offer.
I haven't asked if any of the codes came back.
Old 11-21-2012, 05:24 PM
Looks like this shop is run by morons. Is it a BMW shop?
Old 11-21-2012, 05:58 PM
Dking078's Avatar
Member Supremo
It's a friends shop, they know whats up.. No, not BMW, but they have done a 5HP24 / other BMWs before.
It's just the code so far and behavior of the solenoids so far don't add up after replacing them.
Update : Replaced the Valve body and all soleniods with new ones and it finally fixed the problem. I went over to test drive it, and it shifts and drives like a dream.
I checked codes both in the DME & EGK (transmission) before and after driving and it was all good!
Re Update: I did drive good in testing, but went back to crap going up a hill... Sadly it was the torque converter, R&R'd under warranty with a new unit and should be all good now!
Changing the solenoids & valve body did help quite the problem a bit, but no dice, TC was toast.
