Old 11-08-2012, 11:59 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
First thing to go...???
What is the consensus on the first things to go on these e92s? Any prevents or pre-emptive attacks to employ? I have 32K right now on 335i. Feels, sounds, performs flawlessly (well, as flawlessly as I know it from 3K ago when I bought it).
Old 11-09-2012, 04:42 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
the laser guided rear-mounted rockets tend to miscalibrate around 40k.
Old 11-09-2012, 05:59 AM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
First to go on ours.
Thankfully under warranty.
Stop using the sunroof and you should be OK after warranty expiration!
Name:	sunroof malfunction.jpg
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 11-09-2012, 06:12 AM
Speedwagon's Avatar
Speedwagon Speedwagon is offline
Mein Auto: 2012 328IX Sportwagon
You better sale it fast the rubber band is about to break! ..............
Old 11-09-2012, 06:21 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Rear tires, worn on the inside tread to the cords. Maybe the most common prob of all.
Old 11-09-2012, 09:04 PM
sptt144's Avatar
Sorry for the stupid post...
Old 11-10-2012, 05:48 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
It's not stupid, change your automatic trans fluid and diff fluids more than BMW recommends - 50k would be advisable. Waterpumps seem to go 80-100k fairly commonly, but a bit expensive to be done preventatively. Seems carbon buildup in the intake is common like all DI cars, walnut shell blasting cleans things up and helps performance and potentially valve seal life. Could be done now, 50k anytime, really you can't tell until there is an issue or you take the charge pipe off and take a look inside with a scope.
Otherwise since the fuel pump and injector recalls that seemed to fix up those 2 issues, they seem pretty reliable at least to 100k, not enough data on higher mileage yet!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
