E30 (1982 - 1993)
Old 11-09-2012, 02:20 PM
tymaster00 tymaster00 is offline
Mein Auto: 1985 325e
Oil
Hello everyone. I'm new to the forum and have a quick question.
Basically, is it safe to put synthetic oil in a high mileage engine?
My car has 300k.
Sent from my PC36100 using Bimmer App
Old 11-09-2012, 05:35 PM
BMW318i_'s Avatar
BMW318i_ BMW318i_ is offline
Luke. 2 or 4 wheels
Mein Auto: 04 Yamaha R1, 91 BMW 318i
Depends what weight it is and if It's right for your climate otherwise there's no problem using synthetic oil. But I would stick to good old dino oil if you can. It's much cheaper and there's no need to use synthetic on high mileage cars.
Sent from my HTC Sensation Z710a using Bimmer App
Everything is better made in Germany
Old 11-09-2012, 08:18 PM
downhiller's Avatar
livin large
you can cause oil leaks. synthetics clean the engines really good. so if you have some carbon gunk keeping a gasket sealed, synthetic will pull it out and cause an oil leak.
Old 11-09-2012, 08:40 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
I would suggest not too. Castol gtx has a high mileage semi-synthetic that I ran in my E30 and made it run a little smoother and may have helped with the oil leak it had.
Old 11-10-2012, 03:58 AM
BMWFatherFigure's Avatar
Old School
+1 on Tkaczuk. A Castrol lecture I attended advised use only oil available at the time of an engine's manufacture. That is what it was designed to run on.
Current:
E38 Parts Car
Previous:
Old 11-10-2012, 05:59 AM
Tkaczuk's Avatar
My friend said the same thing. I think same weight in other oils would be okay but more specifically moble 1 would run about the same. I haven't used to many other oils. Royal Purple went in my 24v swap.
Old 11-12-2012, 12:52 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
I have often wondered why some people put synthetic oil into their banger ?
There is a oil for every aplication & just because you abused your baby in the past, expensive oil will not make her love you again
Synthetics are great for high rpm, high heat applications Oh yes, before I forget, they look good in the ads too
I believe in spending my money wisely i.e. Value for money...
So before I spend money on a Lubricant I don't need I will maybe flush that LSD with new oil or the radiator, or maybe even flush the dark juie that started life as hydraulic fluid in your break & clutch system....
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 11-12-2012, 04:03 PM
Thanks for your input.
Old 11-14-2012, 07:19 PM
E30949/909 E30949/909 is offline
Mein Auto: 1990 325IC
Oil
