Old 11-24-2012, 03:47 PM
ctjames3 ctjames3 is offline
Mein Auto: 2006 750li
flat tire
I recently put all new tires on my car, a 2006 750li,I keep getting a red flat tire alarm which will clear after 10 minutes and then come on again. Anyone can give me an idea as to what is wrong, the tire pressures are all good.
Old 11-25-2012, 08:07 AM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
I moved your thread over to the E65 7 series forum for you. You should get the answers you need in here. Try searching this forum for answers as well, someone might have had the same issue before.
Good luck,
Tim
Old 11-25-2012, 09:20 AM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Did you put different size tires in your car. Do you have FTM instead of pressure sensors on the wheels. FTM (flat tire monitor) measures the amount of revolutions a tire makes in a amount of time. If this amount is different than what is saved in memory it assumes your tire is flat. Reset the FTM in the I drive and you should be fine.
Old 11-26-2012, 08:48 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Did you reset the monitor? After tire replacements, air pressure adjustments etc. you have to reset the system using the iDrive menu.
