E60 (2004 - 2010)
Old 11-10-2012, 08:30 AM
Kswan23 Kswan23 is offline
Mein Auto: 530i
Flat tire sensor
Hey guys. Yesterday, I got an error on my dash that says flat tire. I've checked all the tires and they are fine, besides the fact, they are aftermarket 20" tires. They are not connected to the ftm anyway. Is this a sensor that needs to be replaced and if so, where is it located, or can I just reset the error in the idrive?
Old 11-10-2012, 10:01 AM
Mein Auto: 530i
Just a quick update, I went into the I drive and clicked on set tire pressure under the FTM panel anyway, and it cleared out any error messages of flat tires. I don't really understand but I am no longer getting an error.
Old 11-10-2012, 03:35 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
You hit something pretty rough and slowed one wheel down a bit more than the other.
Happened to me before especially with low profile exaggerated rims and tires. The sensor
is on the axle and its a flat tire monitor not tire pressure monitor. So when a wheel on one
axle goes flat, it spins slower than the other wheel on that same axle. The car senses this
and triggers the fault. Not a bad design, but can be annoying because it would just tell
you have a flat and not which tire it is. It's worse with the stock run flats as you would need
a hand held pressure gauge to check every tire as run flats look inflated all the time.
Good luck.
Check your mirrors as often as it takes for you to know where everyone is around you!
Old 11-10-2012, 04:26 PM
Mein Auto: 530i
Thank you makes perfect sense. I reset the ftm in the idrive and it seems to have cleared it out. Thanks again.
