E46 (1999 - 2006)
Old 11-10-2012, 08:53 AM
Rain_xiv Rain_xiv is offline
Mein Auto: 2003 bmw 325i
coolant issues
Whats up.. my car was overheating therefore I replaced the water pump, thermostat, and temp senor. Which in turn fixed the overheating. But now my cars is drinking coolant. I had to top it off twice since eliminating the previous problem, but on my last top off I've notice little browm particles. What is this and why....
Old 11-10-2012, 09:04 AM
Y2K_Bimmer Y2K_Bimmer is offline
Mein Auto: 2000 323i
Little brown OILY particles? or like rust particles?
Old 11-10-2012, 09:15 AM
It isn't rust and I wouldn't say it looked oily. It had a was more in a sense gummy or mushy
Old 11-10-2012, 02:47 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
Ever used stop leak in your coolant system? Sounds like the culprit to me.
Unfortunately though, this could also be a blown head gasket. You need to do a compression test.
Member No. 470379
Old 11-10-2012, 06:06 PM
Joeedawg1911 Joeedawg1911 is offline
Mein Auto: 2002 325i
I'm new here and this might sound like a stupid question, but(here I go) after you changed out all your coolant parts, did you bleed the system properly? (Tip: You'll know if it's not properly bleed if your heater doesn't warm up.) I only say this because the same thing happened to me. My expansion tank cracked, so I changed it out. Filled it up without bleeding it and after running it for 5-10 minutes it said I needed coolant again. Filled it up again and AGAIN, on shut down, said it needed coolant. I started to panic because I thought I might of blown the head gasket. Anyways, If you did bleed the system properly, and your heater does work then it possibly sounds like a head gasket. How long did it overheat for?
Old 11-11-2012, 03:51 AM
todd92 todd92 is offline
Mein Auto: 13 X3 3.5, 05 ZHP
You warped the head when you overheated it. The coolant is going out through the cylinders.
