Old 11-08-2012, 07:42 AM
Snyperx Snyperx is offline
Mein Auto: N/A
Question Brief burnt oil smell this morning.
Seems my issues will never end This morning I was parked at a slight incline. I turned the engine off and ran inside for less than a minute. I came back out and started the car and got a waft of burnt oil smell from the vents. It dissipated in less than a block and never came back after that.
Now if you have been following my other threads over on E90post I recently had the water pump replaced after it failed on the way into work. Could my little incident be related? Could it just be the valve cover gasket at 80k? All input is appreciated.
I would like to mention that the plugs were replaced in the last couple of months with the old ones looking fantastic for having 70k+ on them. I also changed the oil filter housing gasket last year.
Regards,
SnyperX
Old 11-08-2012, 09:54 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
i, for one, have most definitely been following your threads over on E90post.
Old 11-09-2012, 05:38 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
We had valve cover gasket leak with same issues... Check rear of valve cover, near firewall... Oil drips on exhaust, burns off as engine warms up...
Old 11-11-2012, 06:46 AM
Mein Auto: N/A
Excellent. This seems to be where the signs are pointing. For the cost of about $70 I will probably just replace the gasket regardless since it and the bolts are know to have issue on the N52.
Regards,
SnyperX
Old 11-11-2012, 02:41 PM
Salvator's Avatar
Livin' like Larry!
Apparently the rear most bolts are hard to get to... Our dealer replaced our gasket three times (under warranty) before they got it right... Good luck!
