Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 03-11-2013, 12:59 PM
zach0726 zach0726 is offline
Mein Auto: 2010 335d, April build
Fair price for 6yr/100k Platinum Warranty
So what's a fair price for the 6yr/100k Platinum BMW-Factory warranty? I am at 48k and about to pull the trigger. Appreciate any info you may have.
2010 335d, April Build, Michelin PSS, Saddle, Nav, Premium, Winter
1998 Jaguar XK8
2003 Toyota 4Runner
Old 03-11-2013, 02:08 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
Check with Daniel @ pacific bmw: http://www.bimmerfest.com/forums/sho...82#post7408582
Also, Patrick: http://www.bimmerfest.com/forums/sho...bmwpartssource
Old 03-11-2013, 05:30 PM
Thanks Floyd
1998 Jaguar XK8
2003 Toyota 4Runner
Old 03-11-2013, 05:34 PM
Does anybody know if the PowerTrain Plus warranty covers fuel injectors for our Ds? The BMW literature says that it DOES cover fuel injectors in the fuel system but that it DOES NOT cover fuel injectors in the engine. What the.....
http://www.bmwusa.com/Standard/Conte...rotection.aspx
1998 Jaguar XK8
2003 Toyota 4Runner
Old 03-11-2013, 05:36 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
I posted what I recently paid for my extended warranty and extended maintenance.
I went through Daniel at PacificBMW. He did a great job handling this by email and of course you will have to mail a key to him with most recent reading from the car.
I want to say about $2,300 for the Gold level, but check my post somewhere around here.
Old 03-11-2013, 05:47 PM
montr montr is online now
Mein Auto: 335d 2010, 528i 1998
This is a very good question, one section say not covered but on the other section say it is covered. Let us know when you find the answer.
Old 03-11-2013, 07:21 PM
GreekboyD GreekboyD is online now
Mein Auto: 2009 BMW 335d
Zach, I got the BMW business manager here in Toronto to check/verify for me that the injectors were covered under the extended warranty and she said yes.
Old 03-11-2013, 07:23 PM
Talking
Thanks Greek.
1998 Jaguar XK8
2003 Toyota 4Runner
Old 03-11-2013, 07:33 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
I shopped about 10 dealers late last year and the best price I could find was about $3500. This is one of the reasons I traded my 335d before the warranty expired. Didn't want to drop that much in a warranty and afraid to keep the car out of warranty.
Colonel (Ret) US Army / Hagerstown, MD
2010 Z4 s30i Alpine White/Beige
PP/SP/CWP/6MT/CA/NAV/ipod/USB
ED 1-29-10/Redelivery 3-8-10 (weekend car)
2013 Audi A6 Quattro (daily driver)
2011 335d (Ret)
2009 335i vert (Ret)
2007 335i vert (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 03-12-2013, 02:56 AM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
I paid $2,390 for the Gold Extended Warranty from Dan at Pacific BMW. The extended maintenance was $2,095.
Old 03-12-2013, 08:25 AM
Here's an excerpt from BMW's contract for the powertrain-plus warranty. Sounds that that covers our fuel injectors, right? For the SCR system it says the transfer pump and dosing moduel are covered. Does that leave any major gaps in the SCR system?
(i) Engine: Cylinder head(s) and cylinder block. All internally
lubricated parts including: pistons, piston rings and pins; crankshaft,
main and connecting rod bearings; connecting rods; camshaft and
bearings; timing chains and/or belts; sprockets; rocker arms and
shafts; valves, valve springs, upper spring plates (retainers); valve
collets, guides, and seats; hydraulic valve clearance compensators
(lifters); oil pump assembly. Dipstick assembly; vibration damper;
flywheel/ring gear; upper and lower timing case covers; intake and
exhaust manifolds; engine mounts; valve cover(s); oil pan.
(ii) Automatic/Standard Transmission (including SMG
[Sequential Manual Gearbox] and DCT [Dual Clutch
Transmission]): Transmission case, torque converter, all internally
lubricated parts contained within the transmission case including:
all sprockets, shaft bearings, bushings, drums, pumps and valves.
Transmission mount; flywheel; drive plate for torque converter.
Coverage is not afforded for standard/SMG/DCT transmission clutch
assemblies, which are subject to wear and tear.
(iii) Final Drive Assembly, Propeller Shaft(s): Final drive
housing; all internally lubricated parts contained within the final drive
housing including: all sprockets, bearings and output shafts; CV
joints; universal joints; front and rear hub assembly, hub bearings;
propeller shafts.
(iv) Transfer case (xDrive vehicles only): Transfer case, all
internally lubricated parts contained within the transfer case
including: all sprockets, shaft bearings, bushings, drums, pumps
and valves. Transfer case mounts.
(v) Electrical: Alternator/generator; voltage regulator; starter motor, starter solenoid; engine control module; engine and
transmission control modules.
(vi) Cooling System: Water pump; radiator; fan clutch; coolant
recovery tank; additional fan motor.
(vii) Fuel System: Fuel injectors; Piezo injectors; fuel pumps
(including high-pressure pump); metal and plastic lines and fittings;
fuel injection and air flow sensors.
(viii) Induction System: Turbocharger assemblies (vehicles so
equipped).
(ix) SCR (Selected Catalyst Reduction) emission control
system (Diesel Models Only): Transfer pump, dosing module.
1998 Jaguar XK8
2003 Toyota 4Runner
Old 03-12-2013, 06:42 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
I think the DEF also has an ECU, not sure if that is inlcuded in the dosing module or not.
I had to get mine replaced early on during original warranty. Then they had to replace the transfer pump because the heater element went out. They come together. I could have lived without the DEF heater here in S. Florida, but it was covered.
Don't forget you have a $50 deductible + tax for each warranty claim or visit.
Old 03-13-2013, 05:30 AM
Yes, seems like you'd need a DEF cooler in S FL! Appreciate the info.
I'm pretty sure I'm going to go with the Powertrain Plus. Daniel / Pacific showed a great price for that. Meanwhile consumer reports rates the 3 series as "Excellent" for reliability. So I'm not really concerned about the non-D specific gear. I'll "pocket" the $1400 delta btwn Powertrain-Plus and Platinum and see how that bet plays out.
Honestly, I wouldn't be too concerned about the diesel specific reliability except for the inconsistent diesel fuel quality available in the US. My fuel system has been rebuilt from the tank to the injectors due to a bad tank, and so has my neighbor's 335d fuel system! I've gotten a lot more picky about where I fill up........
1998 Jaguar XK8
2003 Toyota 4Runner
HTML code is Off
