Old 11-11-2012, 12:14 PM
trauma1 trauma1 is offline
Mein Auto: 2006 325xi and 2004 x3
Help with battery vs alternator
I have a 2004 x3 and car wouldn't start-heard the tell tale click-click-click. AAA came out and found the battery had a low charge and jumped it. When they tested the voltage across the battery with it running, they said the alternator seems ok(no ripples). Going to get a new battery-the one I have is the original.
Should I still be worried that the alternator could be an issue?
Old 11-11-2012, 12:50 PM
can0n4 can0n4 is offline
Mein Auto: '04 BMW X3, '04 330xi
You need a new battery regardless so just do taht. 2004 on the original battery, its about time it dies. Alternator should not be replaced unless you aren't getting a charge, its not a common thing to change as preventative maintenance, especially if it tested good. Summary.... dont' get a new alternator.
Old 11-12-2012, 07:56 PM
Bmwx3RJ Bmwx3RJ is offline
Mein Auto: 2004 X-3
Same thing
I've been having the same issues with my battery. It has only been getting worse and I still have the original battery. What do you think a reasonable price is for a new battery?
Old 11-14-2012, 07:56 PM
peter_cd.cn peter_cd.cn is offline
I care my ride
Mein Auto: BMW X3
I changed my battery for an after market one
My changed at a local auto shop. Bought an aftermarket battery. The battery match and over achieved the factory requirements, but now the battery will die if I don't drive the car for more than 1 week. Checked the battery condition at multiple repair shops, and passed check.
Don't know why...
I suggest you find a dealer to do this.
Old 11-14-2012, 08:06 PM
mlukas161's Avatar
mlukas161 mlukas161 is online now
Mein Auto: 03 330i, 04 X3
I recommend you don't go to a dealer for this. Expect to pay around 180 for a decent battery. Go to autozone or NAPA. It'll have a breather vent on top of the battery.
The dealer will charge you 500 dollars for something that takes 5 minutes to change.
Old 11-14-2012, 08:14 PM
ProRail ProRail is online now
"Clunker" *****
Mein Auto: 1999 BMW 528A--165K
If you don't go to a dealer at least go to an indie shop that knows about BMWs, or your car will not recharge your battery.
Old 11-14-2012, 08:15 PM
blingin96 blingin96 is offline
Mein Auto: e39 540i , E36 328i
If you don't drive your car regularly it will die. You might consider a trickle charger. I have one on my Harley and my show car. They're only about $35.00
Old 11-15-2012, 05:59 AM
x3oiler x3oiler is offline
Mein Auto: 2006 X3 3.0d
Don't know why...
There are a number of items in the X3 known to NOT shut down when you turn off the ignition. For me - it is the stereo head unit. To test if this is your issue make sure you turn off the stereo manually before ignition off for a while. See how you go = especially if parking for a long time period.
If no difference then search this forum - there are a few causes for excess drain on the battery when the car is "supposed" to be off.
X3 3.0d 2006 (MY07)
Old 11-15-2012, 06:05 AM
mlukas161's Avatar
I really think the problem is just the battery being 9 years old.
Old 11-15-2012, 10:00 AM
I care my ride
Mein Auto: BMW X3
Thanks for sharing your knowledge. I will give a try next time I know I will park it for over a week.
I suspect something is draining battery. Because even the key is off ignition, and I can hear a buzzing noise in the car. Something is not powered off.
Old 11-15-2012, 10:24 AM
I have the same buzzing noise. Mine however shuts off in around 3-5min. Not sure what it is. I think it's my electric fuel pump.
Old 12-09-2012, 01:35 PM
artinstead artinstead is offline
Mein Auto: 2005 x3
ran trickle charger but..
car starts ok but the battery window showed no green, instead a black window. I charged overnight with bmw charger and the final steady green lite on the charger indicated that the battery supposedly was fully charged. I disconnected the charger but the battery still shows a black window. Car starts fine but can't get a cursed green window on the batt. Car is '05, don't know batt age.
Old 12-09-2012, 02:58 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
If you took the battery out and gave it a bit of a shake the little hydrometer might unstick to let the green ball float up.
But it might not - just means that at least one of the 6 cells is not that healthy, but battery still measures at least 12.6V at the posts.
Starting may not be a problem, but losing charge when left for a few days might mean more chance of strange electronic things happening with sensors and warning lights.
If it doesn't show green after a good highway drive and bumping around potholes I'd replace it - 8 years isn't bad for an O.E. battery.
Old 12-09-2012, 04:28 PM
bmwbob89 bmwbob89 is offline
Mein Auto: 2004 X-3 740i 325xi 88M5
The noise is most likely the interior temp sensor fan in the heater panel. Take a listen and see . It should power down after a while.
Old 12-09-2012, 05:14 PM
I found a small battery drain on my car the other day. My glove box light was staying on. The pressure switch in the glove box was faulty. (Just another thing to check out).
Old 12-09-2012, 06:42 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Its a venting system for some charcoal filter in the rear area.
Not sure if anyone mentioned, but the famous parasitic drain is usually the blue tooth not shutting down if you have it.
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 12-10-2012, 09:17 AM
John320 John320 is offline
Mein Auto: 2008 X3.0si
I just had a similar experience with the black spot in my battery: poor, to no crank over power, Black spot wouldn’t go away even after charging the battery with a 6amp charger.
Called the Automobile Association to come and diagnose the problem. They checked the charging system - it was fine, no real drain, battery showed it needed a charge but was ok - well then it had to be the battery - couldn’t hold a charge, only 4 ½ years old. So looked for an after market one, but couldn’t find one in stock that would fit properly ( height problem), so went to my BMW dealer and was pleasantly surprised that the old battery type had been replaced by a new larger one 720 cold cranking amps from 650 (about an inch longer as well) No coding required they said- close enough to original. I had taken a couple of tools, so just bought it and changed at the lot - 5 minute job -then they took my old battery back. All is good-back in action.
Old 12-10-2012, 09:46 PM
Watty3113 Watty3113 is offline
Mein Auto: 06 x3
Replaced my battery on my 06 x3 today. Reset my clock and drove to work. It sat there for a couple hours and when I turned it on the clock was reading --:-- reset clock then drove about 20 minutes. Parked and was inside for about 15 minutes. When I turned it back on the clock read --:-- again. Any idea what could be causing this?
Old 12-10-2012, 10:03 PM
Check fuse #9 (5 amp.) and replace if blown
It provides constant power to the on-board computer (OBC).
With only ignition-switched power the time and trip meter both get reset when ignition turned off.
Fues may have blown from a spike when new battery was connected up, or from a prior jump start.
This has been reported several times here, all 2006 models - but I can't see that is anything but coincidence.
