Old 11-11-2012, 02:44 PM
dabra55 dabra55 is offline
Mein Auto: bmw x3 2006
Exclamation Auxiliary input X3 '06
I have a BMW X3 2006 and I wanted to install an auxiliary input in order to listen to my iPod. I purchased the auxiliary cable from the dealership, found the 3 pin connector under the main compartiment (between the 2 front seats), plugged my 3.5mm cable and hit play on my ipod, but when I turn on my car (and thereof the radio), I still can't access the AUX mode on the radio.
Does anyone have an idea why it's not working?
Old 11-11-2012, 02:47 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Send a message via Yahoo to kjboyd
Mein Auto: 2009 MINI Cooper Clubman
Dealer has to code the system to recognize the aux connection, IIRC.
Kevin
2009 MINI Cooper Clubman - "Oxley"
Nightfire Red/NFR, Tuscan Leather, CP, PP, CW, Roof Rails & Aero Kit, 16" Bridge Spokes, Xenon, Auto, English Oak Trim & Wood Wheel, Alarm, Hi-Fi
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 11-11-2012, 03:38 PM
ducx3 ducx3 is offline
sapper
Mein Auto: 02 WRX, 06 X3
I wired mine in directly to the back of the radio. No coding was needed by the dealer in my case.
Old 11-11-2012, 05:47 PM
Thanks guys for replying. I tried to connect it directly behind the radio, but did not fin a 3 pin connector. Are you aware if there is any?
Old 11-11-2012, 07:25 PM
littleengin littleengin is online now
Mein Auto: 2006 X3 M-Sport
I did the same. Works. Look at the back carefully...It took me a few min to figure everything out but it does work. 2006 x3.
Old 11-11-2012, 07:31 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
Are you using page 9 of the installation instructions?
Depending on whether you have a CD changer installed or not, you may have to disassemble one of the plugs on the end of the radio harness along with the aux-in plug and do some insertions.
If no CD changer installed, you should find just the right space in an existing plug/connector that the aux-in connector fits into.
aux, auxiliary audio input, radio help, x3
