Old 11-11-2012, 06:35 PM
nfakbc nfakbc is offline
Mein Auto: 540i
1997 540i unable to connect to dealer scanner
I have a 1997 540i 6 speed car which has been having some problems (power window, door locks etc, thought it was a bad comfort module but was unable to recode another one to my car). I had the car scanned at both a local dealer and also by a friend with the correct setup to scan my car but the car cannot connect to the machine. I am able to use a generic obd2 scanner to retrieve engine fault codes but cannot retrieve any thing else (abs, airbag, body etc codes).
Any idea what could be going on here or even what to start looking for? Any help would be greatly appreciated!
Old 11-11-2012, 08:20 PM
ninetyseven1 ninetyseven1 is offline
Mein Auto: 1997 540i
you are using the 20 pin round connector under the hood right?
Old 11-11-2012, 08:24 PM
Mein Auto: 540i
Tried going through that connector as well as the standard obd2 port, same result. Any clue what is the first computer/ module in line which these ports try to connect to? From research online it seems to be the gauge cluster but that doesn't seem right.
Old 11-11-2012, 08:50 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The DLC communicates directly with the DME. The DME is the gateway into the CAN Bus, from which all other buses are accessed.
On your MY, the OBD-II connector only carries generic access. The BMW computer uses the 20-pin DLC under the hood, which has all the appropriate signals.
All I can think of is that an earlier owner screwed up when trying to reset the Service Interval Indicator, and may have somehow damaged an input signal to the DME.
Old 11-11-2012, 09:48 PM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
I'd start by looking to see if you have power at certain pins of the 20-pin connector. If you do, the next step would be to check continuity between the connector and the various modules on the bus.
Pins 4, 16, and 14 should all have power from fuses 38, 15, and 114, respectively. If one of those pins doesn't have power, check the appropriate fuse.
http://www.bmw-planet.com/diagrams/r...9old/index.htm
The diagnostic connector is under:
Drive -> Engine (other than M51) -> Engine electrical -> Digital motor electronics -> interfaces, signals -> diagnostic connector -> (then pick the model appropriate for your car)
Old 11-11-2012, 09:58 PM
What's the secret to using this site? I get no connector pinout graphic, just a blank screen.
Old 11-11-2012, 10:05 PM
NADAVAN
no secret, no login, maybe you're missing a plugin or something. I've found there are fewer bugs with explorer than with firefox.
Old 11-12-2012, 09:10 AM
rdl rdl is offline
Mein Auto: 530i 2003
Edjack
You are probably missing the SVG viewer; some systems come with it installed, others not.
You can find the viewer on Adobe's website. Adobe will warn you that the viewer is no longer supported & that there may be security concerns. I've used it for ~3 years without problems. Norton Internet Security has never squawked that anything bad is going on, nor did NIS object about security when I installed the viewer.
Regards
RDL
Old 11-12-2012, 09:36 AM
rdl, thanks, but it appears that they've removed the reader from the donwload area.
Old 11-12-2012, 10:42 AM
Mein Auto: 540i
Where are these fuses fuses 38, 15, and 114 located (these cars seem to have a ton of fuse boxes!).
Old 11-12-2012, 08:56 PM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Fuse 15 & 38 are in the glovebox fuse location:
Fuse 114 is located under the carpet in the fuse box under the right seat:
Q {BMW CCA Member #191509}
(SOLD)
Old 11-13-2012, 08:37 PM
Mein Auto: 540i
Thank you sir, will check those fuses tomorrow.
codes, comfort, obd, p-bus, problems, scanner
