Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 11-12-2012, 10:37 AM
getz's Avatar
getz getz is offline
Mein Auto: 997TT/335xi/R500
Pandora and BMW Apps?
Has anyone else had difficulty getting Pandora to work via BMW Apps?
Any help would be greatly appreciated.
Current: 2012 M-Sport 550i X-drive Dinan Stage 2
Gone but not forgotten: 2007 911 Turbo, 2005 911 Carrera S, 07 BMW M Coupe, 07 335 XI, 05 Mercedes R500
Old 11-12-2012, 10:51 AM
Itinj6's Avatar
Itinj6 Itinj6 is online now
Mein Auto: 2012 650i Convertible
If you mean through the Connected Drive App, it will not work. It's either one or the other. If you select Pandora on your phone or iPod, you should see the Pandora icon in BMW Apps but that's it. Can have both running at once. Same with MOGG, Stitcher, etc (any third party app not included in the Connected Drive App lineup).
Not a fan of this as you have to get to your external device everytime you want to switch between third party apps.
Old 11-12-2012, 10:59 AM
Itinj6's Avatar
***EDIT***
*CAN'T have both running at once*
If you only want to run Pandora solo, it should connect once you attach the USB and you run Pandora on your device... It will pop up under the "Apps" section in idrive and also the "Radio" section.
Old 11-12-2012, 10:51 PM
getz's Avatar
Originally Posted by Itinj6 View Post
***EDIT***
Thanks man. My problem is that if I start Pandora before connecting the iphone, it will run for several minutes, then the BMW apps will shut it down. I am unable to start it via other methods, but it sounds like I need to go into the smart drive and find the Pandora icon there.
Old 11-12-2012, 11:54 PM
Itinj6's Avatar
No prob. Ya, after you plug the phone in the USB and you run Pandora, it should pop up on either the BMW Apps list or the Radio section in idrive. Make sure Pandora on the device shows that you are connected to to the idrive when you run Pandora. There will be a "BMW" on the phone and it will say "Connected".
If all else fails, try rebooting the external device and the idrive (hold in volume/mute button for ~30 seconds). I had a problem a few days ago where my device apps (iPod, MOGG and Pandora) weren't playing audio through the car's stereo. I just rebooted the idrive and it worked.
Good luck!!!
