E90/E91/E92/E93 (2006 - 2013)
Old 11-12-2012, 10:55 AM
T.O.335 T.O.335 is offline
Mein Auto: 335xi M
cleaning MAP and other sensors '09 335xi
Hey guys,
I'm thinking that its worth cleaning the MAP sensor and any other sensors that are exposed to dirt and grime and can become dirty with time. I have searched for DIYs and have come up empty, I was wondering if someone could provide a DIY with pics or at least pictures of where the sensors are located, along with a list of the sensors that need/can be cleaned. Thanks!
Old 11-14-2012, 06:39 AM
Mein Auto: 335xi M
Any ideas?
Old 11-14-2012, 07:52 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
FYI for DIY and maintenance +
http://www.e90post.com/forums/forumdisplay.php?f=16
There are a lot of procedures in the above links.
The MAF Sensor is easy but very fragile.
The other sensors (If it ain't broke don't fix it.)
If you read the Mike Miller schedule he doesn't really say much about cleaning sensors.
And he is the maintenance authority.
The Vanos solenoids are sometimes cleaned to clear up vanos problems.
google Mike Miller BMW
Old 11-14-2012, 09:32 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
The MAF sensor is the only sensor that is ever really cleaned and you need to be real carful doing that.
Old 11-14-2012, 09:36 AM
Mein Auto: 335xi M
From what I have read the n54 engine doesnt have an MAF. I am getting rough cold starts, and would like to clean all my sensors to see if it helps. I have not found any DIY guide on cleaning intake sensors for the n54. Can anyone point me in the right direction?
Old 11-14-2012, 09:58 AM
DSXMachina's Avatar
Automaticallyparsinglinks
Never clean a MAP sensor. Avoid cleaning any other sensor, including your MAF sensor, unless there is an articulable reason for doing so.
Old 11-14-2012, 11:22 AM
Mein Auto: 335xi M
I have actually been having rough cold start issues, with the engine performing smoothly once it is up to temperature. Experience that I have had with other cars previously is that dirty sensors can be the cause of these types of issues.
'09 E90 335xi - M Package - Lemans Blue - 85,000k
Old 11-14-2012, 11:37 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
i see this ending well.....
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 11-14-2012, 11:56 AM
DSXMachina's Avatar
How many miles on your car?
Old 11-14-2012, 11:59 AM
Mein Auto: 335xi M
Just over 85,000 km or 53,000 miles.
Old 11-14-2012, 12:35 PM
DSXMachina's Avatar
The number one cause of rough cold idle* is a dirty throttle body. It's not too hard a job to do on your car. Find a DIY, get a good brush and a can of t b cleaner (Gunk makes a good cleaner). Be careful not to damage the electronic throttle by improperly moving it, and you could solve your problem.
A dirty throttle body virtually never sets a code.
*You did change your plugs already, right? And used BMW plugs?
PS When you start the car after cleaning the tb it will run worse than ever for half a minute. Give it a chance.
Old 11-14-2012, 12:45 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Long cranks?
Old 11-14-2012, 08:34 PM
Mein Auto: 335xi M
Originally Posted by CALWATERBOY View Post
Long cranks?
No long cranks at all, starts right up. I still would like to try to clean sensors if at all possible. I am getting misfire CEL codes but the engine runs wonderfully when warm so I have a feeling its temperature/sensor related.
Old 11-15-2012, 01:25 AM
Specific & consistent? Have to wonder if one or two cyl's only giving trouble.
Old 11-15-2012, 04:55 AM
DSXMachina's Avatar
Did post 11 register at all with you?
Old 11-15-2012, 05:20 AM
Yes, but....
OP hasn't posted codes or lack of. Hasn't indicated whether problem is with certain cyl's or not, and hasn't said whether he's changed plugs or anything else.
So....
Old 11-15-2012, 06:03 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Carboned up intake valves also.
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms|
2009 X5 3.0 - AW- Black Dakota/Bamboo | Premium |Tech | Cold Weather | Ipod | Rear Climate |
07 X3 - Sold
07 335 coupe - sold
Old 11-15-2012, 06:17 AM
i stand by post 8
Old 11-15-2012, 07:39 AM
DSXMachina's Avatar
Yes, but....
So....
Attachment 349632
Sorry Cal, that was directed at the OP.
Originally Posted by Orient330iNYC View Post
i stand by post 8
I think you'll be proven correct.
