X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
Is this what dealer service dept expects ?
Does the typical BMW service department expect the following :
1. Customer knows absolutely nothing. 2. Customer never ever opens the hood to check on the service work. 3. Customer just accepts that whatever work was done was correct. Is this your profile ? I just received mine back , am I asking too much for the following : 1. Oil was overfilled as over fill warning went off, I did confirm it was overfilled by the dipstick, not a sensor issue 2. Oil service was done early ( approx 5000 to go) since it was in for software reprogramming ( they were kind enough to do this ) however this would have been the 3rd service ( should have changed fuel filter along with cabin and air filters ) 3. Coolant resovoir was overfilled above max AGAIN, had to use a turkey baster to remove some ( coolant level was perfect before service ) 4. Had to clean off the remainder DEF fluid again. I only mentioned obviously the oil being overfilled, still awaiting an answer about the items that should have been done with the 3rd service, only response I receive are blank stares, oh by the way when I went to pick up the vehicle they could not find the key dealer ????
Former BMW"s 2003 3.0 X5 ( E53 ) 2002 330 Xi ( E46 ) |
It’s time to change. Definitely
Run!
Looks like you need a new dealer. I have zero issues at my dealer
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
