750Li 06 AC always on? - Bimmerfest - BMW Forums
Old 11-13-2012, 05:36 AM
dseidel dseidel is offline
Mein Auto: 750Li 2006
During moderate weather I don't want AC or Heat on. But the climate system is always on when I start the car. Rather than have to push "off" every time, is there any way to set the default to "off". Can't find it anywhere. Thanks! Don
Old 11-13-2012, 06:21 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Mine does the same thing. I believe its a coding issue...I thought I saw this setting on one of the coding sheets for NCSExpert. If you have the NCSExpert and the cable you can change this setting, if not your INDY should be able to do this. But don't take it to the stealership.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 11-16-2012, 09:30 AM
Control Display always on
Is it possible to set the control display to OFF as default when starting the car?
Old 11-16-2012, 09:42 AM
I turn everything OFF before I shut the car down. However, b/c of the way it's coded, when I start the car the A/C or Heat is ON. Yes, thru coding you can default it to OFF. As soon as I can get my laptop working again, I will check this out further.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
