Old 11-27-2012, 05:28 PM
jcard412 jcard412 is offline
Mein Auto: BMW Z3
Can't get the hood open
I have a 2000 2.3 Z3.
I was lubricating the latch that releases the hood ( this is the latch that pops the hood partially open when you pull the lever under the dash). I sprayed some penetrating oil into the female end of the latch mechanism and I also put a little silicone grease on both left and right male components of the latch system.
(The ones that are attached to the underside of the hood)
I then shut the hood and tried the release lever under the dash so now the hood doesn't even pop to reach in to lift on the latch under the hood.
I didn't do anything to move the hood out of alignment, I just lubricated.
Any ideas on getting the hood open?
Thanks for any help
Old 11-28-2012, 10:05 AM
toddjoh toddjoh is offline
Mein Auto: 2000 z3
Get someone to pull the lever while you apply downward pressure on the hood right above the two latches. There may be too much tension on the latch, not allowing the lever to release. This will relieve some of that tension. Then if you get it open check and adjust the knobs that adjust the height of the hood when closed. They may be to high causing this bind.
Hope this works for you. It did for me.
Old 11-28-2012, 05:25 PM
Mein Auto: BMW Z3
Thanks I'll try it
Old 11-29-2012, 05:06 PM
Mein Auto: BMW Z3
Tried your method but unfortunately it didn't work. However, I used a hanger and was able to snag the hood release cable and the hood popped open. Lucky break!
For now I removed the passenger side hood latch (female part) until I figure out how get to the center junction of the cables to try to take up the slack or replace it.
Thanks for replying to my question
Old 11-29-2012, 06:23 PM
Mein Auto: 2000 z3
http://www.bimmerfest.com/forums/sho...d.php?t=441868
