BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
coyote96 is correct. the "alerts" (open door, fasten seat belts, ect.) show up in HUD by default. I am not sure what the MSA_VERFUEGBARANZEIGE_ENABLE = aktiv does, but is not for those alerts. JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR |
#27
Here is a complete list of what I have coded on the MY 2013 F06:
DVD in Motion Auto Start/Stop to start in the last used setting Unlock doors when engine is stopped Close mirrors, windows and moon roof through key fob and comfort access iPhone ringtone is transferred to car Opening doors (front and back) does not stop window operation HUD Turn signals HUD Entertainment List HUD Phone List iDrive legal disclaimer Camera legal disclaimer TPMS Add pressure and temperature Digital Speed in BC FYI - in my MY 2013 F06 I did not have HU_NBT. I have HU_CIC and made the changes for DVD in Motion to VIDEO_NUR_MIT_HANDBREMSE. I live in Lincoln, NE if anyone in the Midwest needs coding assistance.
2013 650xi Gran Coupe (Born 07-19-2012) M-Sport w/ 20, Black Sapphire, Cold Weather, Luxury Seating, Premium Sound, Ceramic Controls, HUD, Full LEDs, BMW Apps BMWCCA Member |
#28
Here is the document that I created from other documents and posts (some are copies from the F10 Cheat Sheet V3 and some are new).
I am not sure who is keeping the F10 Cheat Sheet up to date but there are a couple of items that I am testing out that we could include. I hope I am not stepping on anyone's toes, just needed to keep things straight in my head while coding and testing.
#29
Here is the file. Sorry, long day!
#30
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#31
Good stuff. What is "The telephone ringtone is transferred to the Combox"? Thanks
'13 640i Gran Coupe Alpine White/Cinnamon Brown, M-Sport, Driver Assistance, Lux Seating, Premium Sound, Full LED's '10 Porsche Panamera S '09 Maserati Quattroporte S '08 550i Carbon Black/Natural Brown/Anthracite, Sport Pkg, Active Steering, Comfort access, Sport transmission, rear shades, NAV, Sirius, L7, Ipod/USB, PDC, Heated Front Seats. '08 750i Sapphire Black/Natural Brown '06 750i Sapphire Black/Natural Brown '07 550i Sapphire Black/Black '05 545i Silver Grey/Black |
#32
You get your Cell Phone Ringtone thought the Car when its connected via Bluetooth, instead on the default BMW Ringtone.
#33
Here are the results of tonight's testing:
Set High Beam Assistant Default to Automatic - Worked Seat Heater Memory - Set to Wert-Dauer (Remember forever) - Worked Auto Dimming Mirrors Disable - Worked (I have tinted windows and it make visibility better with it off) SMS/Email text length while driving - Set to whole text - Worked Triple Turn Signal more than three blinks - FAILED Sport Display - Worked Added Power and Torque to the setting -> Language/Units screen - Worked (Can change values) Digital tachometer and units - Cannot check the box but was able to change the units in the Language/Units screen - FAILED xDrive Torque Distribution - Added the item but cannot select - Going to let the car sleep and try while driving - MAYBE M View in HUD - Displayed in Information screen but was unable to check the setting - FAILED
#34
#35
Yes, it is the new motor. I was surprised it worked too because I don't think anyone with a 550 or 650 had it work.
#36
The N63 motor in the 550i / 650i is an older motor design than the N55 motor used in the 535i / 640i, and I do not think it was originally designed to transmit the data signals, while the later developed N55 motor was. When they updated the N63 to the N63tu, they added them as I suspected they would.
#37
what is the setting to change for : SMS/Email text length while driving - Set to whole text -
#38
I just double checked and bmwvin.com shows N63T for engine.
If there are other coding that need to get tested on this engine, please let me know. Glad to help! I might look into the Speed Limit stuff next, I have the High Beam Assistant. I am also trying the HUD items on the Cheat Sheet to see what works on mine. I need to double check the Seat Heater I coded last night because it was not on this morning and should have been. Seat Heater Memory - Set to Wert-Dauer (Remember forever) - Worked UPDATE - FAILED
#39
HU_CIC / PIM_DRIVING_TEXT_LENGTH = whole_text
#40
#41
Thank for the heads up on the SLI. Based on that news I switched gears to the HUD.
But while looking around in all the modules and found a couple that might look interesting: JBB / 3050 / NACHLAUFZEIT SITZHEIZUNG FRONT Kommentar=Nach KL.15 aus, bleibt den Funktionszustand der Sitzheizung diese Zeit erhalten (OFF TIME FRONT SEAT HEATER Comment = after terminal 15 from, remains the functional state of the seats get this time) JBB / 3050 / NACHLAUFZEIT SITZHEIZUNG FOND Kommentar=Nach KL.15 aus, bleibt den Funktionszustand der Sitzheizung hinten diese Zeit erhalten (OFF TIME SEAT HEATER REAR Comment = after terminal 15 from, maintained the functional state of the rear seats this time) JBB / 3400 / NACHLAUFZEIT LENKRADHEIZUNG Kommentar=Nach KL.15 aus, bleibt den Funktionszustand der Lenkradheizung diese Zeit erhalten (OFF TIME STEERING HEATER Comment = after terminal 15 from, remains the functional state of the heated steering wheel get this time) All three have the same options: 0_min, 15_min, 24_hours and always. The other one I think relates to the fuel reserve - THRESHOLD RESERVE TANKComment = reserve threshold, in 0.25 liter increments Does anyone have any experience with these settings?
#42
I also found this one for the HUD
HUD Enable Voice Command Menu KOMBI / 3000 Anzeige Konfiguration / HUD_SPRACHEINGABE_ENABLE Have not tried it out yet but was in the same grouping as the HUD_TELEFONANRUF_ENABLE and HUD_ENTERTAINMENT_ENABLE which both worked.
#43
SM [6d] / SA_MEMORY_ZEIT = Wert_Dauer or Wert_15 or Wert_00. Comment is: Comment = time after switching off the optional clamp (see SA_Klemmen_FKT) within which a reconnection leads to the reactivation of the same options available seat heating, seat ventilation, massage and active seat in each of the last active stage (delivery condition is equivalent to 15 minutes) 0: (no wake) 0 minutes; 1: 15 minutes; 2: 24 hours; 3: infinity (always reactivate);
#44
I have two different SA_MEMORY_ZEIT settings in different modules. One has the description you listed above and one does not. I am not connected to my car right now, just browsing CAFs offline. Here are the screen shots.
#45
SM [6d] CAF [CFAS_PLX_1] SA_MEMORY_ZEIT Kommentar=Zeit nach Ausschalten der Sonderausstattungsklemme (siehe SA_Klemmen_FKT) innerhalb der ein Wiedereinschalten derselben zur Reaktivierung der Sonderausstattungen Sitzheizung, Sitzklima, Aktivsitz und Massage in der jeweils zuletzt aktiven Stufe fuehrt (Anlieferzustand entspricht 15 Minuten).;;SM [6e] CAF [CBFS_PLX_1] SA_MEMORY_ZEIT Kommentar=Beschreibung siehe CAF Fahrer;;My assumption was always that it was front and rear, but I never went about proving it, so I don't know for sure.
#46
I am confused on the speed limit info. I though the hud or driver assistance package on the 650 came standard with speed limit info. What am I missing?
#47
Maybe he has no DAP though?
#48
If you check post 19 above, I talk there about the HUD_SPRACHEINGABE_ENABLE code. jeg23
#49
Jeg23 - thank you!!
I have just the HUD no driver assistance package. The HUD was a standalone option.
#50
JEG23
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
