E36 (1991 - 1999)
Old 11-13-2012, 01:43 PM
starters a pita starters a pita is offline
Mein Auto: 1998 328i auto
need help!!! rear end vibration with a whop sound any ideas?
the car in question is a 1998 328i auto with 110,000 miles. The vibration is coming from the rear end and makes a whop whop whop sound it whops faster as i speed up and never stops . it sounds like a out of balance tire but i ruled that out after having my rear tires re balanced yesterday... any ideas on what it might be? or any links that would help me?
thanks
Old 11-13-2012, 02:21 PM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
Immediately check your lug nuts make sure they're not loose
Old 11-13-2012, 02:48 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Definitely make sure your lugs are tight, but I'm putting my money on a failed rear wheel bearing. Pretty classic symptoms you are describing.
1998 BMW 328is
1966 Pontiac GTO
Old 11-13-2012, 03:15 PM
i just swapped the back tires to the front with no avail. lug nuts are tight....
i really do hope its just the wheel bearings, what do i have to do check them? take the rotters of for a visual inspection/any play within the bearing? i did the tire wobble test usually when the bearings go the tire wobbles a little bit and its not wobbling.....
the thing is that it doesn't feel and sound like its coming from one specific side
Old 11-13-2012, 03:35 PM
ZeGerman's Avatar
Warm Leatherette
Originally Posted by starters a pita View Post
i really do hope its just the wheel bearings.....
Be careful what you wish for. Replacing rear wheel bearings is a bear of a job, unlike the fronts which are easy to replace.
When I had a failed wheel bearing, it sounded like a worn tire, but I couldn't find any "play" in the wheel itself, nor did I notice any significant change in the loudness under corning load. Nevertheless, I had it replaced and it was definitely the problem. The roar went away. If your brakes aren't rubbing and it does not sound like it's the differential grinding, the chances that it's your wheel bearing are very, very high.
1998 BMW 328is
1966 Pontiac GTO
Old 11-13-2012, 05:13 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
A bear of a job and will run you ~$300-350 per side in labour to have a shop do.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 11-13-2012, 08:46 PM
holy crap just researched the rear bearings a bit fml i miss my 92 vw gti
Old 11-13-2012, 09:39 PM
not sure if this will work on a 98 just yet but worth sharing, to the ones who like to get there hands dirty and dislike giving there money to a mechanic
Old 11-14-2012, 05:05 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Was that $350 total for both bearings or just one? After watching that video I feel inclined to let a mechanic do it!
Old 11-14-2012, 05:46 AM
hornhospital's Avatar
D'oh, You Kids!
$350 for one side.
Quotes to live by:
Old 11-14-2012, 07:11 AM
jonesin's Avatar
The Canadian Prick.
And that video just shows you how to do it if everything goes perfectly.
When they don't go perfectly, like a bearing is seized into the hub, you NEED a hydraulic press to remove it.
Old 11-14-2012, 08:37 AM
r33p04s's Avatar
r33p04s r33p04s is offline
Mein Auto: E36/4/5
Good luck sir I had a similar outlook when mine went...you can drive on it for a *short* while to save some cash
Mine was noticeably wobbling while driving at the time I changed them
Old 11-14-2012, 11:38 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Favorite quote of the day.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
