Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 11-13-2012, 02:05 PM
deluca5590 deluca5590 is offline
Mein Auto: 2001 bmw 330ci
Exclamation overheating problem!!
hello all! need help asap! i have a 2001 bmw 330ci and its over heating. heat dose not work and not sure if that could be the reason its running hot. i changed water pump and thermistate and aslo bled the lines but no go. when it gets close to running hot sometimes the heat kicks on and the temp starts to cool down a little..... any ideas?
