Old 11-13-2012, 03:20 PM
hubbs25523 hubbs25523 is offline
Mein Auto: 97 bmw 528i
car misfires after i changed the plugs
i have a 97 bmw 528i i my starter went out so i put a new one on it and a new crank sensor and then i went and put new plugs in and went to start it up and it wont idle and when u rev it up it pops threw the intake anyone know what could be the probley...could it be the spark plug boots
Old 11-13-2012, 03:49 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Where did you buy the crank sensor? Unless it was a dealer-supplied part, it could be the problem.
Old 11-13-2012, 03:59 PM
i got it from advance auto
Old 11-13-2012, 04:04 PM
ndabunka's Avatar
ndabunka ndabunka is offline
'12 X5 35d Black-on-Black
Mein Auto: X5 35d Sport Black/Black
I've seen others connection the wrong plug wire to the wrong plug during a change. not really THAT hard to do on some cars.
'12 X5d Sapphire/Black/Bamboo, Sport (ZAP), Premium (ZPP) & Premium Sound(ZPS) packages: 20" 214's, OEM Hitch
'11 Victory Ness Cross Country!!!
GONE - '06 750Li Sapphire Black/Creme&Black (Loadeddddd)
Old 11-13-2012, 04:09 PM
cant do that on my ride
Old 11-13-2012, 05:10 PM
went and odered a new crank sensor see if the one i had in there was bad ill find out in the morning if it works hope so
Old 11-13-2012, 05:13 PM
moots's Avatar
moots moots is online now
wat's dat noise
Mein Auto: '97 528i
Chk that the gnd wire (brown) is connected and d plug boots are in fine condition......
Sent from my GT-I9070 using Bimmer App
Fuelly
Why not just install the old one?
Old 11-13-2012, 05:15 PM
ztom's Avatar
ztom ztom is offline
I gotta have more cowbell
Mein Auto: 1997 528i
Crank or cam? Why change crank sensor?
Old 11-14-2012, 06:31 AM
i changed the cranjk sensor cause i broke the one that was in it when i changed the stater i put a new crank sensor this morning , the plug boots look ok , and the brown ground wire is good so u think it could be the cam sensor they wanted $100 for one .... i hooked it up to a machi. and it shot 5 codes p1189- fuel control bank 2 sensor 1 .....p0101- mass or volumn air flow circuit ...p0505-idle air contol system....p0335- crankshaft position sensor "A" circuit....p0420-catalyst system effenciency below threshold... p1750-senconary pressure solenoid circuit range/peformance or system voltage input low ....p0173-fuel trim....... anyone know about these and what ones i need to change to get my car to run
