Old 11-13-2012, 06:30 PM
mjposner mjposner is offline
Mein Auto: BMW M
High Battery Warning
Comes and goes, battery is not that old. No effect except annoyance
Old 11-13-2012, 07:43 PM
HerbP HerbP is offline
Sounds like a problem with the voltage regulator.
Old 11-13-2012, 10:14 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Your battery may be new but overcharging it will kill it in short order. Like Herb said, you should get the alternator (with attached regulator) checked ASAP. The regulator is a $112 part that can be changed on its own.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-14-2012, 04:14 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I wonder if they properly registered the new battery to the car? If you have NCS Expert or DIS software, you may want to check it. If the car thinks it has a larger battery than it actualy has, it will continue to charge even when the battery is full.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
