Fuel pump - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-05-2013, 07:34 PM
Mitsu325 Mitsu325 is offline
Mein Auto: 1993 BMW 325i
Fuel pump
On a real low budget trying to get this 93 325i back into shape, fuel pump is bad (all corroded and jus useless), does anybody have a pump for the e36 4 door sedan available at a good price?
Old 09-05-2013, 07:39 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
should be the same regardless of sedan or coupe...
for the $, i say go with a walbro .http://treperformance.com/i-6323874-...1990-2000.html
just my opinion, though. unless i happen to have an entire assembly already handy i wouldn't bother with shipping a used unit.
df
Old 09-05-2013, 07:42 PM
Fuel pump
Thanx, it should be the same but being specific incase was different....and thanx for the link, I need the while sending unit and all....was hopin somebody would have a used one laying around lol....do you knw of any other types of cars could use this same fuel pump and sending unit?
Old 09-05-2013, 07:58 PM
no. not off hand. you could try checking real oe, to see what other chassis may have used the same assembly, but i don't think you'll find anything other than the e36.
the pump itself would cross over to several chassis, though, but it would need to be removed and installed in the assembly for it to work.
waaaayy too much work for a used pump of questionable service, unless, again, you happen to have one around. then it'll at least get you going until you could get another one.
if you do decide to get the walbro, don't forget to order a sock. get one because you'll need it.
df
