7 Series - E38 (1995 - 2001)
I am having an issue with my heater on a 1998 740il. The blower motor is working fine, however the heat will not come out until I start to drive the car (only blows cold until i drive). I do not know what causes this. Anyone have any solutions? Thanks.
Check your coolant level, be sure that the system is properly bled out as trapped air in the heater coil can cause this. Have you recently serviced the cooling system?
1997 740i- Daily Driver- 18" M-Pars, Depo Lighting, HIDs 1991 Mazda Miata CSP Autocross Beast. too much to list.. 1999 540i M-Sport 6 SPEED- Waiting for upgrades. 2010 Mini Cooper S- Bone stock TURBO Wife's Daily.. |
The radiator was flushed out about a month ago. Not sure if this problem existed before the radiator being flushed. I will check the coolant level, however I am not sure on how to bleed the coolant system. Any insight would be much appreciated! Thanks for your help.
bleeding
Fast enough for me
From memory there is a valve or switch that prevents the heater (heat) working until the engine is up to temp. This item may be giving problems.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
Well the thermostat shows that the car is warm. I will be trying to bleed the system this weekend. Do you guys know where this bleeder screw is for the cooling system? Thanks!
| Tags |
| heater |
