Old 11-13-2012, 10:47 PM
e39540iv8 e39540iv8 is offline
Mein Auto: 2000 BMW 540iA
E39 540i Electrical Issues
Hey guys, just need some help on the enigma aka my 540i.
I came to start the car 3 days ago and the car started weirdly and the cluster didn't work. I also heard weird noises so I turned it off. I tried starting it a few hours later and the car wouldn't turn over, only "click". Now the battery is pretty old, over 3 years but the little button thing on it doesn't show white which means replace. I know that it's not accurate but could this be a battery issue? I say this because now the interior lights, seats and general electrics work sometimes and sometimes they don't. So like I open the door, the interior lights up but I come to do it maybe an hour later it doesn't. Then after say 4-5 hours it works again and then it just doesn't.
The cluster didn't work while the car was running the last time I turned it on which led me to believe the cluster had blown but then the electrics started acting weird and now I just don't know what's going on. Car mechanics show no sympathy either, they charge so much for such little work. I've spent over $3k on this car already and it hasn't gotten better. It's not that I don't have money to spend it's that I don't wanna spend a fortune on this thing. This is by far the most unreliable car I've driven.
Anyways does anybody have any clues I'd really appreciate it.
Old 11-13-2012, 11:14 PM
Plus there's something I found on the drivers side floor. It looks like a piece of metal that's broken off but it's really light. It might not even be a part of the car but if anybody knows what it is would you mind telling me. Thanks
http://farm9.staticflickr.com/8070/8...75f87248_k.jpg
http://farm9.staticflickr.com/8482/8...a8155737_k.jpg
http://farm9.staticflickr.com/8205/8...35944e2c_k.jpg
http://farm9.staticflickr.com/8205/8...5c056d2a_k.jpg
http://farm9.staticflickr.com/8340/8...97e7a0a8_k.jpg
http://farm9.staticflickr.com/8209/8...059f5b82_k.jpg
Old 11-14-2012, 03:26 AM
Euromanonly Euromanonly is offline
Mein Auto: 99 Bmw 528it
To me it looks like a piece of a motor mount bracket or a piece of the engine block "corner of it"..
Old 11-14-2012, 04:05 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
Do you have a voltmeter? It would be nice to see the battery voltage before, during, and after your attempted cranking.
I was first thinking a problem with the battery, but with your description of the flaky electronics, I wonder if the ignition switch is failing. It can cause some flaky behavior. It's fairly easy to replace.
Take a look at #2 in this picture. #6 is the lock cylinder where your key goes. The end of the lock cylinder meshes with the ignition switch.
http://www.realoem.com/bmw/showparts...03&hg=32&fg=30
Old 11-14-2012, 04:10 AM
Are you serious? It came from under the steering wheel. It was inside the car on the driver's side.
Old 11-14-2012, 03:08 PM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
Sounds like a bad battery. Get this one charged and a volt meter to see if the alternator is really charging the battery properly.
2000 540/6 Slightly tweeked...everywhere
