E60 (2004 - 2010)
Old 11-14-2012, 09:35 AM
Ralph III Ralph III is offline
Mein Auto: 2007 530xi
Spark Plug Gap and Torque Specs????
Hello All,
Can anyone give me the spark plug gap and torque specs for a 2007 530xi. I'm installing some Denso Irridiums(sk20hr11)....
Thanks,
Ralph
Old 11-14-2012, 11:09 AM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
Originally Posted by Ralph III View Post
Hello All,
Thanks,
Ralph
Pre-gaped to 0.044" and I don't think they require adjusting.
23ft-lbs dry (without anti seize).
Old 11-14-2012, 01:18 PM
Thanks for the input.
What's the torgue with anti-seize? Otherwise, should I torgue a few pounds less/more when using such? BTW, I always check the gap of spark plugs for consistancy and accuracy.
Ralph
Old 11-14-2012, 07:10 PM
Mein Auto: 545i
Ralph
RE anti-seize I don't use it as BMW and Bosch recommend you don't. When I changed the factory plugs at 82K miles they came out easily.
However, there are many that swear by the use of anti-seize and I wouldn't argue with them if it works well for them.
If you use anti-seize, apply it sparingly. I would back off to 20 lb-ft to avoid over-torqueing.
