The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition. |
Observations of a PC virgin
Well, yesterday I finally decided to try out the PC and bits that I'd bought earlier from another 'Fester. This was a chance to strip off my previous, unhappy experience with Meguiar's NXT and go back to good 'ol Klasse AIO+SG. So after reading up on some old threads here, I decided to have a go.
So I did the Dawn, clay (didn't need much of that since I clayed prior to NXT), and decided to try Griots Polish 3 that was in the package of stuff I bought. I have to say it was NOT the product to try first-time-out with the PC. Even though I was using the correct pad (Griots orange) and the correct speed, I think I used too much product. I did the hood and a door, and decided to just take it off, which was a PITA. And it didn't do jack for some of the fine scratches and marks I had on my hood. Oh well. I'm going to have to get some hands-on tutorial or something before I tackle polishing again. AIO was a completely different matter. Using Griots red pad, it couldn't have gone better. The pad did shed a little at first. The softness of the pad was just right for the AIO, and the fact that I used less product and the PC got it on much more evenly meant removal (hand) was easy, and the end result was fantastic. On to SG. I only had the 2 Griots pads, so earlier yesterday I went out and got the softest pad Meguiars sells, the SoftBuff pad. This pad is somewhere between the red and orange Griots pads, and I didn't like it very much for SG. It seemed to like being slowed down a bit, so I took it down to 3, which helped, but I can't help but wonder if it would have been even better with a Griots red. In any case, I discovered that the SG set up hard, and was about as hard to remove as if SG is normally left on overnight (I probably left it on about 1.5hrs while I had dinner), and I had to use a bit if QD to remove. So I have Klasse back on my car again (yay!) and have some time with the PC under my belt. I recall reading that one of you regulars uses a PC for AIO but not for SG. Is there any particular reason? And for those who do use the PC with SG, do you have any suggestions?
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline 1988 M6 Royalblau/Silbergrau Nappa |
I too found that #3 polish did nothing for my hood scratches, #2 helped a bit but I am still a bit dissappointed
2012 135 Coupe Alpine/Black; M Sport, Premium 2, 7 sp/dual clutch, HK, Sirius, Apps, Nav, Heated Seats |
Guys, #3 isn't going to do jack for anything most of us would consider meeting the criteria of a "scratch". Your disappointment is a result of mis-set expectations, not the product.
#3 is exceedingly mild as an abrasive. It is meant as a final polish, so it has very little cutting action. It's best for removing minor swirls in the very top of the clearcoat, removing mild hard water spots, discontinuity in the reflectivity of the surface due to bug guts, bird droppings, etc. And again, only for relatively mild stuff. Remember that "bee sh!t" thread I posted last year? That stuff always leaves a slight dull spot on my paint that is damage to the very top surface of the clearcoat... #3 usually takes this sort of thing right out. It will not be hidden with washing, claying, and wax, however. It is damage in just the top molecular layer or two. To get out or reduce the visibility of bonafide scratches that penetrate the clearcoat layer significantly (less than 20%), you'll need to do some careful work with #2 or even #1, then work your way back up to #3 as a final polish. #1 will result in a dull appearing surface, revealing the abrasive, high-cutting nature of the product. #2 will also, but it is far more subtle and less noticable. Scratches that exceed 30-35% of the thickness of the clearcoat are basically not repairable with polishing. You can knock them down quite a bit and make them far less visually apparent, then with some good glaze or wax, can fill them to the point that they can only be seen if you know where to look and point them out. Anything that makes it all the way through to the color layer is just SOL. You've got to live with it. I can say from direct experience that you do not want to try to repair such a scratch with clearcoat and wetsanding. Almost impossible. Down to the primer, and, well, if you have a dark car you pretty much have to do some sort of touch-up / wetsanding process to tone it down and keep it from grabbing the eye. Back to the subject at hand, #3 is perfect for a regular, twice a year polishing to clean up the paint surface, polishing out those spots of dullness that accumulate from suicide bugs and flying creature droppings, as well as other assaults. This routine, followed by a good wax job, and the car will look fabulous. However. use the wrong product for the wrong application, and you will be disappointed. |
"When the going gets weird, the weird turn pro." - HST |
Guess I'll read up on autopia tomorrow during a hopeful lull at work.
AIO on the other hand was easy to do with the PC and white pad from CMA. I have 2 3M products and orange pads awaiting use to get to the acid rain spots on my horizontal surfaces. Maybe I'll get to that this week. I can't speak highly enough about the Klasse products. I've done 3 cars, VW, Honda and my 5'er so far. The black VW which sits outside 24/7 looked brand new when I finished the whole treatment of clay, AIO and SG.
Jeff R. Golden Gate Chapter BMW CCA - Autocross - Come Join Us! ![]() "You drive like old people $#@%... slow and sloppy!" - George Carlin |
I don't get it. Everyone says to use 'thin coats' but when the same people talk about how much they use or how many applications from a bottle they get, it sounds like they're drowning in the stuff. Which is it???
).From what I understand, less is more. I haven't used SG on the 5'er yet, still have some work to do on the horizontal surfaces, then I will. From what I read here, using too much will require considerable effort to remove SG. Even the thin coat I used on the Cabrio and Honda required some QD for complete removal after letting SG set for about 2 hours. I spritzed, then used microfiber towel to remove and buff out - came off pretty easily. I also read recently that application followed by immediate removal is the recommended process, even though the bottle says otherwise. Hmmmm.
You really need to work the Griots Polishes going over 3'x3' areas in crisscrossing patterns until the polish almost disappears, use some pressure and adjust the speed setting so the polisher does not bog down, and change the pads a couple of times. Wipe off the product promptly after you finish each area. Like RKT BMR mentioned if you have deep swirls you need to start with #2.
I recently did a #3, AIO and Carnauba detail on my Midwest winter driving '01 and the results were excellent. |
~One man’s opinion / observations ~
There are two schools of thought on removal (the so-called WO/WO)wipe on, and then remove the residue or allow it to cross-link for 1 hour + and then remove residue. The secret to the application of a polymer product is to apply it thin (super thin) Fill a spray bottle and mist a foam pad for application. Apply this product using water-dampened applicator, and then spray the applicator with Sonus Spritz. Apply Klasse products very thinly using absolute minimum pressure on the applicator. Everything in a straight line, circular movements only add to swirl marks. Spray the vehicle surface very lightly with Sonus Spritz between each Sealant Glaze ‘layer’. Use a slightly damp 100% cotton towel to wipe the surface followed by a dry 100% cotton towel to remove Sealant Glaze ~Hope this helps~ Experience unshared; is knowledge wasted…/ Jon justadumbarchitect * so I question everything * |
(rkt bmr's fine too if you prefer...)
I used 1 through 3 on my 325, but it was already so beat that swirl marks wouldn't hurt it any more. I have yet to see a PC-ed car that doesn't have swirl marks/microscratches, so I avoid it, m'self.
Even Steve Griot has them on display: Although, when you pull back from up close, the car looks fine.
"This is a revolution, dammit! We're going to have to offend SOMEbody!" |
Probably should clay before polishing with the PC to minimize the spider web swirls.
I'm thinking those swirls were there already, before PC'ing. If a finish got to that stage where #1 griots is needed, it's in fairly bad shape to begin with.
I clear coated some helmets, wetsanded with 2000 grit to get rid of the orange peel, then used a PC with 3m Imperial medium cut compound, followed by 3m glaze. No swirls. However, this is on soft clearcoat (had only cured for a couple hours), so I don't know if that would make a difference. |
Has his dad seen that? Is he still in the will? The RKT on it's worst days doesn't look like that, up close, under the lights.
I never put the machine to my paint surface unless it has been freshly washed and clayed. NEVER.
I don't know how quickly everyone else manages to do it, but enough stuff lands on the car between the time I'm finished with one process and go onto the next that it needs a wipe-down before I can start.
#25
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
