E36 (1991 - 1999)
Old 11-14-2012, 12:25 PM
robant251 robant251 is offline
Mein Auto: E36 328i Cabriolet
Question Spurious messages
The computer on my 1998 328i convertible has started displaying intermittent messages telling me I either have a tail light or brake light which has failed when, in fact, there is no problem with any of the lights.I have been told this sometimes occurs when a reasonably new bulb is paired with a reasonably old bulb and the computer wrongly thinks the older bulb has failed.With this in mind I have replaced both bulbs with new items but still have these messages. Can anyone please help?
Regards.
Bob Riley.
Old 11-14-2012, 12:51 PM
ECSTuning's Avatar
Mein Auto: e30
Bob check the bulb sockets for corrosion. I've seen numerous cases where a little build up still allows the power to flow to the bulb but doesn't allow the car to see the bulb.
800.924.5172
OEM BMW Part Number Search
Old 11-14-2012, 12:56 PM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
The check control measures the current drawn by each bulb, individually: the measurement of one bulb should not influence the measurement of another.
You may be suffering intermittent connections from corrosion between the bulb holders and the sheet metal strips they twist into. Have you tried cleaning them?
Old 11-14-2012, 01:28 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 BMW 325i Convertible
I found it was the socket seating that was dirty on mine and drove me "nutz" for awhile...changed lamps, checked springs etc....finally cleaned socket seating and been fine since...go figure???!!!???
Old 11-14-2012, 02:22 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '96 328iC, '04 325Ci
If you are getting the Brake Light failure message then what John F, jitsjaf, and ECST indicated should fix it whether it's the tail or brake light. If the message is Brake Circuit failure then you need to look at replacing your brake light switch which is another known failure item on E36s.
'96 328iC "Marie"
Old 11-14-2012, 02:39 PM
mfisher0000's Avatar
mfisher0000 mfisher0000 is offline
Mein Auto: 08 335i, 98 323ic, 05 V50
Same thing happened to me. I replaced both bulbs and cleaned the sockets and it cleared the message. I've also read that a weak or failing battery can cause this message.
Michael - Terre Haute, IN
