Old 11-14-2012, 12:50 PM
ALM168 ALM168 is offline
Mein Auto: Z3, e46, Ford Explorer
Z3 Fail NJ Inspection for leaking gas cap
Here in NJ, the motor vehicle inspectors only check emissions either at the tail pipe on older cars or using the on board diagnostics via the OBD port and for any leaking of the evaporative gas system. My 98 Z3 2.8L passed the OBD tests, but failed for a leaking gas cap. My question is if the gas cap was leaking, shouldn't it have thrown an error, i.e. "small evaporative leak" Has anyone else seen this?
Thanks,
Al
Old 11-14-2012, 01:10 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Cap should throw a code.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 11-14-2012, 01:21 PM
I am hard pressed to believe the cap is bad. The MV inspector said that he ran the test twice, but if the equipment (I am thinking the adapter was wrong or bad) is faulty, it really doesn't matter how many times you run the test.
Al
Old 11-14-2012, 02:01 PM
Monolith Monolith is offline
Mein Auto: 1997 Z3 1.9L DASC Auto
Have it retested at another location.
Old 11-14-2012, 02:51 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
or just buy another cap and get a good sticker.................how much is an after market gas cap compared to to prolonging the hbo drama
Old 11-14-2012, 05:03 PM
Yep, that is the plan to purchase another BMW OEM gas cap, but neither BAV or Pelican has fitment for my 98. I will call BAV tomorrow to see if they carry one, as is not available on line. It's not the $25 that's got me, it's having to go back to the MV inspection station and waste another hour sitting in line.
Al
Old 11-14-2012, 06:11 PM
You don't wait in line. You go to the exit side and tell them you want your cap re-inspected. They should just walk it up the line and do the vacuum check on it and give it back to you. Give them a call and explain what the failure was and how to get it rechecked.
Old 11-15-2012, 05:23 AM
dougmcintyre dougmcintyre is online now
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Or you could just replace the filler cap gasket - part no. 16116755071, MSRP $2.07
Old 11-16-2012, 05:04 AM
The original gas cap # 16116750571 and the rubber washer # 16116755071 are discontinued. A relacement cap # 16111184664 is available.
MV told me that they stopped the reinspection at the back door and I will need to wait in line for the new gas cap to get checked.
BUT, back to my original question, "...if the gas cap was leaking, shouldn't it have thrown an error, i.e. "small evaporative leak" ?
-Al
Old 11-16-2012, 06:02 AM
-Al
it should throw a code. i had a ford ranger pu fail NJDMV gas cap test but not show a cel. did you try getting a cap from an auto supply store [pep boys etc] ? your car tests one way and NJDMV tests another way..................aint fair but ya wanna good sticker ya gadda play by nj rulesi live in trenton and dmv wait time varies at trenton mostly very fast [the few times i have gone] it takes more time to do the paper work than the testing
Old 11-16-2012, 06:09 AM
I purchased a new cap at Princeton BMW, and will go back to Baker Basin when I get time off from work. I am feeling that the inspector was not performing the test correctly or using the wrong adapter, but I will go back with my receipt for the new cap and see what happens.
Al
