Old 11-25-2012, 10:46 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
Anyone have a bad throttle valve actuator that they can pull apart?
Does anyone have an old bad throttle valve actuator that they might be able to pull apart? I'm trying to find out if the nylon gear in the regular throttle valve actuator is the same as the one inside the supercharger boost pressure controller (a similar butterfly valve) on the B7. Thanks in advance!
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
