E90/E91/E92/E93 (2006 - 2013)
Tire pressure sensors
Hello Guys/Gals,
I recently moved to Montana and we get a great deal of snow. I am wanting to switch my summer wheels (19's) back to my stock wheels(16's) with a little more aggressive tire for winter. I ran into a problem at the tire place (les schwab) saying that the "tire pressure monitoring system" was corroded to the valve stem and couldn't swap the sensors over to my winter wheels. I went to a second party BMW auto shop and he quoted me $100 each ($400) total for new pressure sensors for my winter wheels. So I guess I am asking if there is a way around the TSP warning light just for the winter? or am I kind of stuck paying $400 for the sensor & tire stem plus whatever it cost to mount and balance the wheels? Also is there any cheaper place to buy these sensor other then the dealer? Thanks for all your help, Montana Guy 328XI |
They're about $200 cheaper on eBay.
Frederic |
Tps
Thanks I will look there
+1 on TireRack being able to provide replacements (with warranty and the right frequency) for around $200. The sensors they sold me for my winter tires have been just fine.
While many people have put non-TPMS wheels on their cars for the winter, I believe NHTSA is starting to crack down on the practice, going after installers who put non-TPMS setups onto a TPMS car. I would think it would work out to your advantage to have 2 sets of wheels, each with its own set of sensors. You save possible wheel scarring / pulling / installing / rebalancing costs to the tune of $100 every 6 months.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion |
How do they know? |
Undercover agents. Seriously. With all the other problems in this country and the fight over financial resources, TPMS stings get funded.
There's credence to that - half the population spying on the other half; every current & former govt worker views civilians are people in need of behavior modification. Do we live in Nazi Germany, or the Soviet Union? |
They do have "rebuild kits" for these TPMS but it's difficult to imagine the extent of corrosion you have. All four would be strange IMO. A TPMS can be ruined by a shop inserting a brass valve core during tire service vs. the required nickel plated valve core (prevents galvanic corrosion). We rarely hear of TPMS corrosion issues in here.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
TPMS rebuild kits don't replace the stem they replace most all the other components but that. I have a kit for mine since I figure eventually it will need rebuilt.
Just get 4 new TPMS and have them installed in the snow tires and enjoy life. Life expectancy is about 8 years on these Li-Ion batteries and once they are shot the TPMS is shot. |
Big opportunities for indy shop owner's...and I expect that some will retire to Jupiter Island in Florida when this is all over...does Tiger own a BMW?
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA Last edited by pointandgo; 11-15-2012 at 05:49 PM. |
The NHTSA is not cracking down on the practice of putting non-TPMS wheels on a TPMS car; what they're doing is taking a harder look at those who put run-flat tires without TPMS onto a TPMS car, and dictating that all cars equipped with run-flats are eqiupped with TPMS going forward. The NHTSA is unable to stop you installing non-TPMS equipped tires on your TPMS car; what they can do is if a run-flat tire without TPMS loses pressure and then fails (i.e. the sidewall gives out either because you're driving too fast or too far) causing any significant damage to your car or others then that would be grounds for a report to your insurance company that they may use to deny a claim. If you have non-run-flat tires (normal tires) on a TPMS equipped car, then it's reasonable and prudent to assume that you are well aware when your tire goes flat because the car handles like crap. It's no different than in a non-TPMS equipped car at that point. The NHTSA is not a police force; they are an advisory body only. Even in the event you run run-flats without TPMS then it's actually quite unlikely that you're going to get yourself in particularly hot water because in order for an insurance claim to be denied it would have to be proved that the lack of TPMS caused the issue... i.e. you would have to have a sidewall of a run-flat fail hard and actually be unable to control the car. In either instance you're probably going too fast or shouldn't be driving anyway; I've had a run-flat fail hard (not a BMW) and the likelihood of you losing control is exactly the same as if you had a tire blow out. No, I'm not an attorney but I am well familiar with the NHTSA and what they can and can't do.
2001 E46 BMW 330i Sport Package 6MT *SOLD* 2004 BMW R1150GS - *SOLD* 2004 E60 BMW 545i Sport 6MT - *SOLD* 2012 BMW 135i - Deep Sea Blue / Terracotta / DCT 2012 BMW K1600GT - Vermillion Red Metallic http://www.driveblog.net |
http://tires.about.com/od/Tire_Safet...ng-Sensors.htm Nope, they're a government agency that provides interpretation of federal codes for police forces and prosecutors to use. Just like the FDA inspectors who can and do walk into my clients' production facilities at their discretion. They can pass out paper, but that's it. If you get them upset enough, though, they can and do return with people carrying guns who will take other steps. Again, I never said they could come after the owner of the car. I said they're cracking down on installers, and are providing a legal framework for local forces to do so. Clearly Not nearly as clear
Zooks is correct (link)...making an item subject to motor vehicle safety standards (fmvss) "inoperative" by a shop is highly frowned upon and subject to civil penalties. Another subject of NHTSA's scrutiny are auto parts subject to fmvss, but not marked with the necessary 'DOT' to indicate they meet federal testing requirements. Not too many years ago in the L.A. area a distributor of "car boy" aftermarket auto lighting was caught selling non-DOT approved lighting. NHTSA nailed them for about $600,000+.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
