Old 11-14-2012, 05:00 PM
ZEEKHAN ZEEKHAN is offline
Mein Auto: 535
$75 Oil Change Special?
Have a special at my local bmw dealer. Is it a good deal? Also hoe often is oil change recommended by BMW of North America? I have a 2008 535xi. Thanks guys.
Sent from my SGH-T999 using Bimmer App
Old 11-14-2012, 05:34 PM
Akshun Akshun is offline
Fastman
Mein Auto: 2008 535xi
That's not a good deal. That's a standard price. I have an 08 535xi too. Oil changes come every 15k miles depending upon how you drive. The car constantly recalibrates itself. Drive like a maniac you'll change it more often.
Dinan stage 2 software
Dinan exhaust
Dinan floormats
Black matte grill
M5 spoiler
K&N filter
Old 11-14-2012, 05:38 PM
Mein Auto: 535
Well I put about 250 miles on my car every week. And I drive normally. Is it done every service due? Also when its time would it be easy to just buy the oil from the dealer and get it done at a indy shop?
Old 11-14-2012, 05:42 PM
Fastman
There is a separate meter that calculates it. Just tap idrive and navigate a lil bit and you'll see how many miles you have left. It has nothing to do with the service due. It'll specifically say "oil" and the miles you have left. Why go to an Indy shop? At $75 every 15k you spend less over the course of a year anyway. Might as well have the pros do it.
Dinan exhaust
Dinan floormats
Black matte grill
M5 spoiler
K&N filter
Old 11-14-2012, 06:26 PM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
For that price get it done at the dealer - synthetic oil is not cheap. The car should have an oil change every 15K according to BMW - to me that is way too long. I have been getting oil changes every 7,500 miles.
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 11-14-2012, 06:28 PM
Kushp14 Kushp14 is offline
Mein Auto: 2005 BMW 530i Sport-Sold
yes its a good deal, around here its 85
Old 11-14-2012, 06:36 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
don't go 15K, regardless of what BMW says
Old 11-14-2012, 07:07 PM
Mein Auto: 535
Thank you guys...
Old 11-14-2012, 07:11 PM
5k-7k is good
Old 11-14-2012, 08:25 PM
Mr.750 Mr.750 is offline
A BMW, 7 Series of course
Mein Auto: LS460
$75 for an oil change!? Damn you big states are lucky.. I have to go 45 minutes for a BMW stealership and they get $129 for it.
Old 11-14-2012, 08:26 PM
Ralph III Ralph III is offline
Mein Auto: 2007 530xi
That's a good deal. Our dealership charges around $120.00 for oil changes and consequently why I do it myself! The next nearest dealership (Pensacola) charges $100.00. I'd jump on $75.00 given full synthetic is so expensive. BTW, my car states 16k miles between oil changes but I'm changing every 12k mi. We're pretty easy on our vehicles with mostly interstate driving.
Ralph
Old 11-14-2012, 08:42 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
It's not a bad price for a dealer but if you're into very simple DIY you can do it by yourself using top notch oil and OE or OEM filter. Cheaper and better results.
Old 11-15-2012, 06:55 AM
colin007 colin007 is offline
Mein Auto: 2007 530i
how exactly is it "better results"? i know the guys in my shop and they do excellent work.
Old 11-15-2012, 08:35 AM
Well, I can't speak for your dealership, but some BMW dealership tech damaged the oil drain plug threads on our car at some point in it's history. When the warranty ran out I began servicing the car myself but was always leery of the drain pan threads. They felt damaged or soft to me from the beginning. Sure enough, what few threads had actually been holding gave way on my last oil change. I had to re-tap the hole and install a HeliCoil.
I also just discovered our lug nuts were significantly over torqued, having had new tires put on recently, by another tech (not BMW). Those are supposed to be torgued around 85lbs but had to be over 150lbs. In fact, I had to buy a larger air gun to break those loose but still have three in the back which won't give. They'll be getting a call today about that.
I think what UltimateDriving is saying is, these are issues which would have been avoided by a competent self servicing car owner who has a vested interest.
Take care,
Ralph
Old 11-15-2012, 09:26 PM
Mein Auto: 535
So my idrive system says oil change in 5k miles. If I change my oil before those 5k miles come up. Will my idrive pick that up automatically and reset?
Old 11-15-2012, 09:58 PM
That would be nice but the answer is "No". You have to do the following steps to reset service components.
1) Turn the car to "on" but do not start.
2) Press and hold the odometer button until the maintenance symbols are displayed.
This can be kinda tricky sometimes, so just keep trying until the symbols show. If some maintenance code numbers begin to display, seems to happen after numerous attempts, just turn the car off and try a little later.
FYI, you can go into the I-drive to see what the symbols stand for in needed. Start from the main I-Drive window, push the knob down (as if selecting "I") then; Info Sources>Service Information>Service Requirements
3) Scroll through the maintenance symbols by pushing the odometer button.
4) When the desired maintenance symbol is highlighted, push and hold the odometer button until it prompts you to "Reset". Press and release the odometer button again to ok that. You have to go through each individual service component as such, but this is how it is done...
Good luck,
Ralph
Old 11-16-2012, 11:09 AM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
I just got a similar coupon in the mail from my local dealer. In small print at the bottom were the words "synthetic oil extra, limited to 5 quarts". Is there a BMW built in the last 10 years that doesn't require synthetic oil? And, I know my car takes way more than 5 quarts.
The "coupon" went in the trash!!
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 11-19-2012, 08:03 AM
Mein Auto: 535
Thank you Ralph. Will try this.
Old 11-20-2012, 03:47 PM
bschmidt25 bschmidt25 is offline
Mein Auto: '07 530xi, '01 525iT
If you can actually get it done for $75 that's a pretty good deal. I change the oil myself and it's almost $55 just for materials:
7 quarts of M1 0w40 @ $6.50 / quart: $45
Mann filter: $8.50
Easy DIY by the way. It's easier on an E39 because you can use an oil extractor through the dipstick tube - no need to get under the car. But I digress... Don't want to open that can of worms...
