Old 11-04-2012, 12:04 PM
tmartin000 tmartin000 is offline
Mein Auto: 2009 BMW 528xi
error message pic--what's wrong?
My orange blinker is fine.....I think its my Angel eyes..
Old 11-04-2012, 01:47 PM
NoQuarter's Avatar
NoQuarter NoQuarter is online now
Mein Auto: 2008 535xi
Did you stand in front of the car and take a look?
Old 11-04-2012, 01:58 PM
Here are a couple of pics. One is the passenger side, the other is the drivers side--(where the error references)
The key in, ignition on, but engine not running, with the Parking lights ON only
ID:	348372   Click image for larger version
Old 11-04-2012, 02:17 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
The Drivers side looks like the ONE bulb for the Corona Rings went out and the car defaulted back to a High beam bulb (reduced intensity).
Never seen that before. You don't have Xenons so your inner lights are the DRL's., but since you have the switch in parking lamp mode DRL's are not active.
If not you would have Bi-Xenons on the outer bulbs.
Those inner lights serve as cornering lights only if you have xenons, and flash to pass if you don't. So, it looks to be the Driver side Corona Ring Bulb that's out.
Still confusing however. Need a tool to acces the LM and see whats really going on.
Old 11-04-2012, 02:19 PM
PharoE39's Avatar
PharoE39 PharoE39 is offline
SPIRIT-FILLED DRIVER!
Mein Auto: 1987 325iS 5MT, 2005 530i
angel eye is out on driver side. may need to change bulb. not a hard fix for the basic DIY.
02/87 Zinnoberrot 325iS 5MT
09/04 TitanGrau II Metalic 530i
Sport Pkg.///ColdWeather Pkg./// AC Schnitzer Type IV
06/97 AlpinWeiß III 528iA
///M Bronze Double Spoke 65///'01 Hella AE's///Remus muffler///Mstyle Front & Rear///ACstyle CF Spoiler & Front Splitters///Black Wide Kidney Grill///Sliding/Opening Leather Center Armrest
EntwurfsDriftenFahren/DriftDraftDrive
Old 11-15-2012, 08:34 PM
This is NOT an H8 bulb that I was told was the problem...!!
Old 11-15-2012, 09:47 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Looks like you have halogen lights and not bi-xenon so a h8 bulb will not work. If your car is a 09 it's probably under the BMW maintenance plan unless you have over 50k on the odometer. That would be covered under that plan.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 11-15-2012, 09:50 PM
What ****en pisses me off is that idiots told me to get an H8 bulb.
Thank you though....
Old 11-16-2012, 01:30 AM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
[QUOTE=boramkiv;7175290]The Drivers side looks like the ONE bulb for the Corona Rings went out and the car defaulted back to a High beam bulb (reduced intensity).
QUOTE]
What???? The car does not default to the high beam if the AE goes out. If you look at the pics, the DRL's are on in both pics. It just more obvious in the pic with the AE that's out. The OP needs to replace that AE bulb which can only be purchased at the dealer.
OP, if your car had Xenons, then the AE would take the H8 bulb. This is always listed in the reference books at the auto stores. They fail to list the correct bulb for the Halogen headlights. Nobody sells that bulb besides the dealer so don't waste your time in looking.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 11-16-2012, 06:22 AM
boramkiv's Avatar
Propellers Up Front
I only said that because the OP stated the key in ignition not running and PARKING LIGHTS ON ONLY. Once you turn your parking lights on the DRL's go out and the Angel Eyes come on. DRL'S on the LCI five without Xenon are high beams with reduced intensity unless you use NCS or some other means of coding to do otherwise. Either way the conclusion is the angel eye (not DRL) bulb is out, and the OP understands that.
Old 11-16-2012, 06:39 AM
[QUOTE=2chill;7197942]
QUOTE]
Thanks for taking the time to reply.
AFTER I understood what the heck to look for, and two hours of searching, I ordered 4 of the tiny Philips or Osram bulbs. I took the assembly apart and goggled the bulb's part number.
What pisses me off is how ****en difficult it was to figure it out.
Old 11-16-2012, 07:55 AM
pcy pcy is offline
BMW wants you to take the car to dealer to replace that bulb. Dealer can charge you $600 to replace that bulb and REGISTER [your name in to the suckers list] the bulb to the car's electronics. If you don't register, you will get all kinds of electrical problems.
Old 11-16-2012, 09:52 AM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
His: 2017 X4 M40i with all the options (except cold weather stuff - not needed in SoCal
Hers: 2007 X3 3.0Si
